RTEMS gdb script
Chris Johns
cjohns at cybertec.com.au
Thu Dec 12 02:58:45 UTC 2002
Joel Sherrill wrote:
> That's a good idea. Do you have an example?
I use the follow commands to help remove the C type syntax from general use:
# Commands to ease the C notation of GDB.
# These command read and write 8, 16 and 32 values.
define set8
set *((unsigned char*) $arg0) = $arg1
end
document set8
Set 8bit memory: set8 ADDRESS VALUE
end
define set16
set *((unsigned short*) $arg0) = $arg1
end
document set16
Set 16bit memory: set16 ADDRESS VALUE
end
define set32
set *((unsigned long*) $arg0) = $arg1
end
document set32
Set 32bit memory: set32 ADDRESS VALUE
end
define d8
x /$arg1b $arg0
end
document d8
Dump 8bit memory: d8 ADDRESS LENGTH
end
define d16
x /$arg1h $arg0
end
document d16
Dump 16bit memory: d16 ADDRESS LENGTH
end
define d32
x /$arg1w $arg0
end
document d32
Dump 32bit memory: d32 ADDRESS LENGTH
end
define uhelp
help user-defined
end
document uhelp
List user commands.
end
> I think it needs to be .. Any suggestions on a real name and a location
> in the source tree.
rtems-score-gdb
or
rtems-cpukit-gdb
Chris Johns, cjohns at cybertec.com.au
