Synching clock manager
Arun Govind arun_jeevi at lycos.com
Tue Dec 17 09:26:10 UTC 2002
thank you for your response.
I wonder what should you have meant by a *separate* hardware clock. I'm using a my PC itself as the target and all I wanted to synch the time with the BIOS time. I used the rtems_clock_set using a hard coded time and that worked. But how can I get the current time from BIOS? Sorry, I don't know much about BIOS routines.. Is there any prebuilt function that will do that?
Arun
On Tue, 17 Dec 2002 17:01:53
 Ian Caddy wrote:
>Hi Arun,
>Yes, if you have a seperate hardware clock, you will need to get its
>time on startup and then perform:
>    /* Now we set our system time */
>    status = rtems_clock_set(&tRTEMSTime);
>This can be performed in your init task when your system starts up.
>regards,
>Ian Caddy
>Arun Govind wrote:
>> Do I need to call some special routines to synch the rtems clock manager with the hardware clock? I've #defined CONFIGURE_TEST_NEEDS_CLOCK_DRIVER    in my test. But any calls to get the current time returns me some time around midnight, January 1st 1988.
>> thanks for any help
>> Arun
>> _____________________________________________________________
>> Get 25MB, POP3, Spam Filtering with LYCOS MAIL PLUS for $19.95/year.
>> http://login.mail.lycos.com/brandPage.shtml?pageId=plus&ref=lmtplus
