Fwd: RTEMS core: bad work with _Watchdog_* ?
Ilya Alexeev ilya at continuum.ru
Mon Feb 4 14:52:52 UTC 2002
Hi all.
I has tried to send this message only to Joel,
but I has received a returned mail with something about that domain isn't in
a list of allowed rcpthosts... So I send this to rtems-users...
I am using the latest RTEMS snapshot and
see such effect:
Then I create very many tasks which are calling
rtems_task_wake_after in the infinite loop, there is a very big chance
that such task isn't wake up.
I am using the gen68360 bsp.
Here is the application which I use for test:
////////////////// begin of application //////////////////////////
#include <termios.h>
#include <rtems/libio.h>
#include <fcntl.h>
#include <bsp.h>
static rtems_task
testTask(rtems_task_argument argument)
    rtems_event_set events;
    while(1)
        rtems_task_wake_after(1);
//      rtems_event_receive(RTEMS_EVENT_1, RTEMS_WAIT|RTEMS_EVENT_ANY, 1,
&events);
rtems_task
Init(rtems_task_argument argument)
    rtems_id tid;
    int i;
    for (i = 0; i < 50; i++)
        rtems_task_create(rtems_build_name('T','E','S','T'),
            100, RTEMS_MINIMUM_STACK_SIZE, RTEMS_DEFAULT_MODES,
            RTEMS_DEFAULT_ATTRIBUTES, &tid);
        rtems_task_start(tid, testTask, 0);
    puts("\n");
    while(1)
        printf("%08d  ", _Watchdog_Ticks_since_boot);
        fflush(stdout);
        rtems_task_wake_after(5);
    rtems_task_suspend(RTEMS_SELF);
#define CONFIGURE_MAXIMUM_SEMAPHORES                    8
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS        8
#define CONFIGURE_MAXIMUM_TASKS                         64
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_MICROSECONDS_PER_TICK                 1000
#define CONFIGURE_EXECUTIVE_RAM_SIZE                    (1024*1024)
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_INIT
#include <confdefs.h>
////////////////// end of application //////////////////////////
I see only a some numbers which are printed from the Init task,
and then all output stops.
Changing rtems_task_wake_after directive to the rtems_event_receive with
the same timeout does not made the good situation too.
As I understood, both this directives (wake_after and event_receive) works
with the _Watchdog_Ticks_chain.
Clock interrupts handler works with this chain too
(_Watchdog_Tickle_ticks() directive).
In my opinion, there is no appropriate protection of this chain
then rtems_task_wake_after() and _Watchdog_Tickle_ticks() routines
are called 'together'.
When I added to the rtems_task_wake_after directive (taskwakeafter.c)
_ISR_Disable(level) at the beginning and the _ISR_Disable(level) at
the end, things goes much better!
Output from the my application is nevers stops.
Also then I modified the _Event_Seize directive by the same way
(I removed the _ISR_Enable - _ISR_Disable around the _Watchdog_Initialize),
my application begin to work good with the rtems_event_receive() directive.
What can you say about this?
Does such changes really needed to the RTEMS core or I mistake somewhere?
Best regards,
        Ilya Alexeev.
