Fwd: RTEMS core: bad work with _Watchdog_* ?
Gerke Kok gerke.kok at tpa-nl.com
Wed Feb 6 15:37:20 UTC 2002
Is this all on the 68360 BSP? Cause I have some interrupt related problems with it. It lloks like some interrupts can disabled after a while for no part. reason. It might just be mee but when I read anything like this it gets my hopes up the answer is near :-)
Thanks anyway,
Gerke
*********** REPLY SEPARATOR  ***********
On 06/02/02 at 16:10 Ilya Alexeev wrote:
>> I have been working offline with Ilya and sent him the suggestion
>> to comment out the _ISR_Flash in src/watchdoginsert.c.  Then he should
>> have a finer grain view of the problem.
>> --joel
>Yes, after commenting out _ISR_Flash in src/watchdoginsert.c
>my 'stress test' works fine.
>There were a some my incorrectness in the previous letter:
>the application worked good with _ISR_Disable/Enable around the
>_Watchdog_Insert_ticks only.
>Ilya.
