RTEMS sound device driver
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Feb 8 14:07:59 UTC 2002
Pattara Kiatisevi wrote:
> OK, meanwhile I am trying this static method as you suggested while
> waiting for the new dynamic one. (In the hope also to understand more
> about RTEMS)
> 1.I created sound.h in my local application directory containing:
> #define SOUND_DRIVER_TABLE_ENTRY \
> { sound_initialize, sound_open, sound_close, \
> sound_read, sound_write, sound_control }
> and the declarations of these 6 functions (copied from in console.h).
> 2.I created sound.c containing:
> rtems_device_driver sound_initialize(
> rtems_device_major_number major,
> rtems_device_minor_number minor,
> void *arg
> rtems_status_code status;
> * Register Device Names
> status = rtems_io_register_name( "/dev/dsp", major, 0 );
> if (status != RTEMS_SUCCESSFUL)
> rtems_fatal_error_occurred(status);
> * Initialize Hardware
> return RTEMS_SUCCESSFUL;
> For the rest 5 functions, I just have "return RTEMS_SUCCESSFUL;" inside.
> 3.In my application header, I have such thing like this:
> [cut]
> #define CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
> #define CONFIGURE_MAXIMUM_DRIVERS 10
> #include <console.h>
> #include "sound.h"
> rtems_driver_address_table Device_drivers[] = {
> CONSOLE_DRIVER_TABLE_ENTRY,
> SOUND_DRIVER_TABLE_ENTRY,
> { NULL, NULL, NULL, NULL, NULL, NULL }
> #include <confdefs.h>
> [cut]
> #define open_mode 1
> #define DEVICE_NAME "/dev/dsp"
> [cut]
> /* Open sound device */
> if ( (audio_fd = open(DEVICE_NAME, open_mode, 0) ) == -1 ) {
> /* open of a device failed */
> perror(DEVICE_NAME);
> exit(1);
> Then I compiled and ran the code and got this error:
> /dev/dsp: Too many open files in system
> Do you have any clues?
The error message was actually right in this case. :)
By default, RTEMS only provides 3 file descriptors (stdin, out,
and error).
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS XXX
where XXX is some number greater than 3. :)
> Thank you very much,
> Pattara
> On Thu, 7 Feb 2002, Aaron J. Grier wrote:
> > On Fri, Feb 08, 2002 at 12:02:33AM +0100, Pattara Kiatisevi wrote:
> > > But how exactly is this "registering" process? I took a look at the
> > > existing driver code as suggested and draft the steps as follow.
> > rtems_io_register_name binds a name in filesystem space to the device
> > driver.
> > > -I create a file contained device driver's code: sound-driver.c
> > > -Which should contain initialize(), open(), close(), read(),
> > > write(), and control(). Arguments of these functions = like in console.c?
> > yes.
> > > -In the initialize() I would have sth. like:
> > > -In my application file, I do open(), ioctl(), write(), close() to
> > > /dev/dsp as usual.
> > you understand correctly.
> > > -And then how can I tell RTEMS to call this sound device driver when there
> > > is access to /dev/dsp?
> > after registering the device with rtems_io_register_name, you can
> > perform standard operations like open(), close(), lseek(), dup(), etc.
> > on your file. RTEMS handles the "mid level" between these calls and
> > your device driver calls.
> > > Something to do with #def CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE and I
> > > have to create my own Device_drivers? (Hmm, but how and where? :) )
> > look at c/src/lib/include/console.h. you define a table entry, and the
> > extern declarations for your driver entry points, then somewhere in your
> > confdefs.h:
> > getting everything glued in to autoconf/automake so that they will be
> > compiled and linked into your BSP is a whole other story. :) let us
> > know if you need help with that.
> > Aaron J. Grier | Frye Electronics, Tigard, OR | aaron at frye.com
> > "In a few thousand years people will be scratching their heads
> > wondering how on earth the first computer was invented and
> > bootstrapped without a prior computer to do it with."
> > -- Chris Malcolm, on comp.arch
joel at OARcorp.com On-Line Applications Research
