problems with "configure" options
Mon Feb 11 23:30:31 UTC 2002
This is a bug which was spotted in time to be fixed in
the last snapshot.
--joel
Thomas Doerfler wrote:
> Hi,
> currently I want to rebuild the RTEMS snapshot (20020118)
> without killing my previous installations on my computer.
> Things work rather fine with the toolset, I have
> GCC/Binutils/Newlib in a dedicated installation directory
> /opt/rtems/binutils-2.10-gcc-2.95.3-newlib-1.9.0
> instead of
> /opt/rtems
> Now things get a bit in the wrong direction: I try to prepare
> the RTEMS library build with:
> ../rtems-ss-20020118/configure  --enable-rtemsbsp="mbx860_002
> mbx821_001" --target=powerpc-rtems --prefix=/opt/rtems/ss-
> 20020118;make all
> and everything compiles right. But when I try to install the
> system with
> make install
> I find out, that part of the system still installs to
> /opt/rtems
> and not to
> /opt/rtems/ss-20020118
> as given in the prefix option of "configure".
> I found out, that the "prefix" is not propagated to the
> subdirectories. In the "top-level" Makefile, "prefix" is set
> to the right value, but under "./power-pc/c/Makefile", prefix
> is once again "/opt/rtems".
> Any ideas what might go wrong?
> Ah, yes, I am working on a SuSE7.3 Linux with autoconf V2.52
> and automake 1.4-p5
> any help welcome...
>         Thomas.
> IMD Ingenieurbuero fuer Microcomputertechnik
> Thomas Doerfler           Herbststrasse 8
> D-82178 Puchheim          Germany
> email:    Thomas.Doerfler at imd-systems.de
> PGP public key available at: http://www.imd-
> systems.de/pgp_key.htm
