problems with "configure" options
Thomas Doerfler Thomas.Doerfler at imd-systems.de
Tue Feb 12 07:40:07 UTC 2002
Hello Joel,
> This is a bug which was spotted in time to be fixed in
> the last snapshot.
I have downloaded ss-20020205 and tried it there
but it seems not be working there aswell...
> --joel
> Thomas Doerfler wrote:
> > Hi,
> > currently I want to rebuild the RTEMS snapshot (20020118)
> > without killing my previous installations on my computer.
> > Things work rather fine with the toolset, I have
> > GCC/Binutils/Newlib in a dedicated installation directory
> > /opt/rtems/binutils-2.10-gcc-2.95.3-newlib-1.9.0
> > instead of
> > /opt/rtems
> > Now things get a bit in the wrong direction: I try to prepare
> > the RTEMS library build with:
> > ../rtems-ss-20020118/configure  --enable-rtemsbsp="mbx860_002
> > mbx821_001" --target=powerpc-rtems --prefix=/opt/rtems/ss-
> > 20020118;make all
> > and everything compiles right. But when I try to install the
> > system with
> > make install
> > I find out, that part of the system still installs to
> > /opt/rtems
> > and not to
> > /opt/rtems/ss-20020118
> > as given in the prefix option of "configure".
> > I found out, that the "prefix" is not propagated to the
> > subdirectories. In the "top-level" Makefile, "prefix" is set
> > to the right value, but under "./power-pc/c/Makefile", prefix
> > is once again "/opt/rtems".
> > Any ideas what might go wrong?
> > Ah, yes, I am working on a SuSE7.3 Linux with autoconf V2.52
> > and automake 1.4-p5
> > any help welcome...
> >         Thomas.
> > IMD Ingenieurbuero fuer Microcomputertechnik
> > Thomas Doerfler           Herbststrasse 8
> > D-82178 Puchheim          Germany
> > email:    Thomas.Doerfler at imd-systems.de
> > PGP public key available at: http://www.imd-
> > systems.de/pgp_key.htm
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel at OARcorp.com                 On-Line Applications Research
>    Support Available             (256) 722-9985
