Compiling/installing RTEMS under Cygwin
Robert S. Grimes
rsg at mediaone.net
Mon Feb 18 04:19:08 UTC 2002
I'm trying to compile and install RTEMS under Cygwin. The crossdevelopment
tools are installed and working, but when I try the following command, it
doesn't work:
../rtems-4.5.0/configure --target=m68k-rtems --disable-posix --disable-tcpip
--disable-cxx --enable-rtemsbsp=efi332 --prefix=/opt/rtems
I get the following output from this command:
creating cache ./config.cache
checking for RTEMS Version... 4.5.0
checking host system type... i386-pc-cygwin32
checking target system type... m68k-unknown-rtems
checking build system type... i386-pc-cygwin32
checking rtems target cpu... m68k
checking for a BSD compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking whether make sets ${MAKE}... yes
checking for working aclocal... missing
checking for working autoconf... missing
checking for working automake... missing
checking for working autoheader... missing
checking for working makeinfo... missing
checking whether to enable maintainer-specific portions of Makefiles... no
checking if the test suites are enabled? ... no
checking if cpu m68k is supported... yes
updating cache ./config.cache
creating ./config.status
creating Makefile
creating tools/Makefile
creating make/Makefile
creating make/custom/Makefile
creating make/Templates/Makefile
creating make/compilers/Makefile
creating doc/Makefile
configuring in tools/build
running /bin/sh
../../../rtems-4.5.0/tools/build/configure --target=m68k-rtems --disable-pos
ix --disable-tcpip --disable-cxx --enable-rtemsbsp=efi332 --prefix=/opt/rtem
s --cache-file=../.././config.cache --srcdir=../../../rtems-4.5.0/tools/buil
loading cache ../.././config.cache
checking for a BSD compatible install... (cached) /usr/bin/install -c
checking whether make sets ${MAKE}... (cached) yes
checking for Cygwin environment... no
checking for mingw32 environment... no
checking for executable suffix... configure: error: installation or
configuration
problem: compiler cannot create executables.
configure: error: ../../../rtems-4.5.0/tools/build/configure failed for
tools/build
Does anyone have a clue for me? Thanks!
-Bob
