Compiling/installing RTEMS under Cygwin
Mahesh Revuri maheshr at in.ceeyes.com
Mon Feb 18 04:53:25 UTC 2002
Hi,
        It seems that your cygwin is not fully configured. While installing
cygwin, enable all in the list of tools to be installed from cygwin installation
tool.
Mahesh Revuri
"Robert S. Grimes" wrote:
> I'm trying to compile and install RTEMS under Cygwin.  The crossdevelopment
> tools are installed and working, but when I try the following command, it
> doesn't work:
> ../rtems-4.5.0/configure --target=m68k-rtems --disable-posix --disable-tcpip
>  --disable-cxx --enable-rtemsbsp=efi332 --prefix=/opt/rtems
> I get the following output from this command:
> creating cache ./config.cache
> checking for RTEMS Version... 4.5.0
> checking host system type... i386-pc-cygwin32
> checking target system type... m68k-unknown-rtems
> checking build system type... i386-pc-cygwin32
> checking rtems target cpu... m68k
> checking for a BSD compatible install... /usr/bin/install -c
> checking whether build environment is sane... yes
> checking whether make sets ${MAKE}... yes
> checking for working aclocal... missing
> checking for working autoconf... missing
> checking for working automake... missing
> checking for working autoheader... missing
> checking for working makeinfo... missing
> checking whether to enable maintainer-specific portions of Makefiles... no
> checking if the test suites are enabled? ... no
> checking if cpu m68k is supported... yes
> updating cache ./config.cache
> creating ./config.status
> creating Makefile
> creating tools/Makefile
> creating make/Makefile
> creating make/custom/Makefile
> creating make/Templates/Makefile
> creating make/compilers/Makefile
> creating doc/Makefile
> configuring in tools/build
> running /bin/sh
> ../../../rtems-4.5.0/tools/build/configure --target=m68k-rtems --disable-pos
> ix --disable-tcpip --disable-cxx --enable-rtemsbsp=efi332 --prefix=/opt/rtem
> s --cache-file=../.././config.cache --srcdir=../../../rtems-4.5.0/tools/buil
> d
> loading cache ../.././config.cache
> checking for a BSD compatible install... (cached) /usr/bin/install -c
> checking whether make sets ${MAKE}... (cached) yes
> checking for Cygwin environment... no
> checking for mingw32 environment... no
> checking for executable suffix... configure: error: installation or
> configuration
> problem: compiler cannot create executables.
> configure: error: ../../../rtems-4.5.0/tools/build/configure failed for
> tools/build
> Does anyone have a clue for me?  Thanks!
> -Bob
