Interrupts occurrence
Angelo Fraietta angelo_f at bigpond.com
Fri Feb 22 21:41:02 UTC 2002
I worked it out. I did not have the interrupt pin held high for long
enough. I am now generating and decoding interrupts every 1 Ms.
Angelo Fraietta wrote:
> At what speed can I have interrupts happening in the pc386 bsp running
> at 16 MHz. I am generating an interrupt with an external
> microcontroller -- currently every 30 Ms (I was hoping to make it
> possible every 1 Ms) -- however, the 386 is missing some of the
> interrupts.  I am attempting to transfer data between the
> microcontroller an the 386 by using a 16 Bit device driver and using
> interrupts to synchronize the two processors. Should I be trying to
> use DMA for data transfer rates of this speed?
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
    Bernard of Clairvaux (1090 - 1153)
