Newbie question to i/o
Thomas Doerfler Thomas.Doerfler at imd-systems.de
Mon Feb 25 08:01:36 UTC 2002
Hello,
> the systems i know allocated a piece of static storage to all major
> (device) and minor (unit) instances of a device driver. if an interrupt
> was connected to the device the systems interrupthandler setup a pointer
> for the static data area of that device. currently i've no idea how to
> setup a static data area for every minor device and have a pointer
> defined to this area when the interrupt service routine is entered.
> can anybody please explain the mechanisms behind the screnn to me and
> all other who don't know? thank you very much.
In RTEMS, it is the responsibility of the device driver to
allocate any resources needed for device operation. So if you
want to implement the static storage area, the device driver
must allocate it (using a "region" or "malloc" call),
initialize it with proper data (whatever is needed there) and
store its address for further use. An alternative aproach
would be to define an array of data structures/buffers in the
device driver source code, with one element for each minor
device number used.
Then, in the interrupt handler, you must determine, for which
minor device you are working, you may use the vector number of
the interrupt or some device specific information to
distinguish that. Then you can use the proper pointer to the
minor device data area.
So in short, you have to "emulate" the mechanism you mentioned
on your own.
wkr,
	Thomas Doerfler.
> Schöne Grüße aus Reutlingen
> Wolfram Wadepohl
> Entwicklung
> INDUMAT GmbH & Co. KG
> Transport- und Lagersysteme
> Dieselstraße 6
> D-72770 Reutlingen - Betzingen
> Tel.  +49 (0)71 21/5 14-2 89
> Fax   +49 (0)71 21/5 14-2 99
> eMail W.Wadepohl at indumat.de
> WWW   http://www.indumat.de
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler           Herbststrasse 8
D-82178 Puchheim          Germany
email:    Thomas.Doerfler at imd-systems.de
PGP public key available at: http://www.imd-
systems.de/pgp_key.htm
