Missing /dev/null dll
charles at embsyspro.com charles at embsyspro.com
Tue Feb 26 00:20:09 UTC 2002
Silverio,
I had to rebuild GDB with the latest Cygwin installed on my Win2K machine
and that seems to have eliminated that problem, but has caused some new
problems.  One puzzling thing is that after I unzipped and d'tared the
'mips-rtems-gdb-5.0-5.tar.bz2' file that is located in the 'cygwin-test'
folder the 'mips-rtems-gdb' and the 'mips-rtems-run' programs did not
automatically have the default '.exe' extension.  You may just want to what
until one of the RTEMS developers can take a look at the issue.
CLN
> -----Original Message-----
> From: Silverio Diquigiovanni [mailto:silverio.di at qem.it]
> Sent: Monday, February 25, 2002 6:04 AM
> To: charles at embsyspro.com
> Subject: Re: Missing /dev/null dll
> Please can you explain me how you have solved the question ?
> I've some problems with my sh-rtems-gdb
> Thank you
> ----- Original Message -----
> From: <charles at embsyspro.com>
> To: "Rtems-Users" <rtems-users at oarcorp.com>
> Sent: Monday, February 25, 2002 12:41 AM
> Subject: RE: Missing /dev/null dll
> > Please disregard this, I found the problem.
> > > From: charles at embsyspro.com [mailto:charles at embsyspro.com]
> > > Sent: Saturday, February 23, 2002 10:02 PM
> > > To: Rtems-Users
> > > Subject: Missing /dev/null dll
> > > Hi,
> > > The mips-rtems-gdb from the cygwin-test folder requires a dll
> > > called /dev/null.  I have not experienced this error before.
> > > Does someone know what it means?
> > > CLN
Sign Up for NetZero Platinum Today
Only $9.95 per month!
http://my.netzero.net/s/signup?r=platinum&refcd=PT97
