Cannot build RTEMS..Problem with configure script
Satyaki Mukherjee satyaki at tataelxsi.co.in
Tue Feb 26 09:33:47 UTC 2002
Hi Joel,
	Thanks for the inputs. I could go a little ahead with building RTEMS.
However, I got stuck again at a different place while running the
configure script. This time the error message reads:
checking for make/custom/i386.cfg... configure: error: no
configure: error: ../../../rtems-4.5.0/c/configure failed for c
Any clues regarding the same would be highly appreciated
TIA
satyaki
-----Original Message-----
From: Joel Sherrill [mailto:joel.sherrill at OARcorp.com]
Sent: Saturday, February 23, 2002 8:53 PM
To: Satyaki Mukherjee
Cc: rtems-users at OARcorp.com
Subject: Re: Cannot build RTEMS..Problem with configure script
Satyaki Mukherjee wrote:
> Hello Everybody,
>         I am facing problems while trying to build RTEMS on sun sparc.
> I had successfully installed the prebuilt toolset executables (for
> 1386-rtems)
> in /opt directory. The same has been verified by using a small program
> as described in the documentation. I had also set PATH variable to
> $PATH:/opt/rtems/bin before checking the toolset.
Do you have gcc.exe linked to cc.exe?  The autoconf scripts
expect you to have a native C compiler named cc.
> Now, on trying to build rtems using configure script for
> TARGET=i386-rtems
> BORAD_SUPPORT_PACKAGE=i386
> I get the following error :
> Checking for automake....missing
> Checking for Cygwin...no
> The compiler cannot create executables...installation problem
> Can anyone suggest where the problem could be?
> TIA
> satyaki
