link() fails?
Mike Panetta
ahuitzot at mindspring.com
Wed Feb 27 04:16:00 UTC 2002
I am in the middle of debugging the MRM332 BSP, and I am having a
strange error. In console_init(), there is a piece of code that links
/dev/sci to /dev/console. The link command is failing, saying links are
not supported. What could cause this? The exact test in link.c that is
failing is this: if ( !parent_loc.ops->link_h ), on line 72 of link.c.
Does this clue anyone in? I think this may be all I need to resolve to
get this BSP to work. Could I not be including some FS or FS option on
the configure line when I am configuring RTEMS that would cause this?
This has definatly been a fun ride (I had to debug and fix the BDM
driver to even get this far ;), so it will be worth it to see this BSP
working.
Thanks,
Mike
