link() fails?
Eugeny S. Mints Eugeny.Mints at oktet.ru
Wed Feb 27 10:44:32 UTC 2002
On 26 Feb 2002, Mike Panetta wrote:
> I am in the middle of debugging the MRM332 BSP, and I am having a
> strange error.  In console_init(), there is a piece of code that links
> /dev/sci to /dev/console.  The link command is failing, saying links are
> not supported.  What could cause this?  The exact test in link.c that is
> failing is this: if ( !parent_loc.ops->link_h ), on line 72 of link.c.
> Does this clue anyone in?
It seems you have configured miniIMFS instead full IMFS - in
miniIMFS such functionality as link is absent - use full
IMFS.
>I think this may be all I need to resolve to
> get this BSP to work.  Could I not be including some FS or FS option on
> the configure line when I am configuring RTEMS that would cause this?
> This has definatly been a fun ride (I had to debug and fix the BDM
> driver to even get this far ;), so it will be worth it to see this BSP
> working.
> Thanks,
> Mike
Eugeny S. Mints
OKTET Ltd.
1 Ulianovskaya st., Petergof, St.Petersburg, 198904 Russia
Phone: +7(812)428-4384 Fax: +7(812)327-2246
mailto:Eugeny.Mints at oktet.ru
