Interrupt disabled in ISR
Leon Pollak leonp at plris.com
Thu Feb 28 15:03:47 UTC 2002
Hello,
	I shall be very thankful for the explanation of the following moment:
In the PPC code file irq_stub.S routine __ISR_handler I see that all
interrupts are disabled almost immediatly. They are reenabled at the end of
the ISR, after the user ISR has finished its processing, almost at the point
of exit.
	The text contains the comment after the _ISR_NestLevel incrementing:
"From here on out, interrupts can be re-enabled, RTEMS convention says not".
	Why?
Thanks.
leonp at plris.com
