[FWD: Patch for rtems-ss-20020118, to fix MRM332 BSP (prelim, CFT)]
Mike Panetta
ahuitzot at mindspring.com
Thu Feb 28 22:31:46 UTC 2002
Apparently the list did not like my Bcc: only email ;)
-----Forwarded Message-----
Subject: Patch for rtems-ss-20020118, to fix MRM332 BSP (prelim, CFT)
Date: 28 Feb 2002 14:08:06 -0800
Here is a patch that has resulted from the debug sessions and fixes that
I have done to the mrm332 bsp in RTEMS. Its only a prelim patch, and it
could still be cleaned up a bit, but if anyone is willing to help test
and has an MRM332, I would love it if they would give it a try. This
patch does not set up the autoboot feature of CPU32BUG. I have
temporarily commented out that piece of code, because it was messing up
GDB. The final patch will not have this issue. Additionally, I have
only tested this patch with the code in RAM. I have not tested a flash
load of RTEMS yet.
This patch has updated the start code in the BSP. It has split the
origional start code in to 2 parts, a small bit of ASM, and some C init
code. It has also added a new SPI driver (Thanks Joel :), that should
be more stable then the old one. So far its only set up to do polled
IO, but I am going to try to get interrupt driven IO to work.
I have tested this patch against some of the tests in the test dir. The
ones I have run so far are: sp09, sp21, sp26, ticker, and base_sp. The
only test that failed, is sp21, and it failed at the end. I think the
failure may be due to the test thinking major 5 was invalid, and it may
not be in this BSP. I will be running more tests (of course).
This patch may apply against newer snapshots, I have not tried yet. I
may try soon, but I want to try to narrow down any bugs to my changes,
so I want to reserve testing this code on a newer snapshot to after I
have finalized my changes. If someone wants to get frisky and test the
patch against the newest snapshot, go right ahead but don't expect me to
be too excited about fixing any bugs that appear ;).
Thanks for your help,
Mike
diff -Nur rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/console/Makefile.am rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/console/Makefile.am
--- rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/console/Makefile.am Fri May 25 10:35:09 2001
+++ rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/console/Makefile.am Sun Feb 24 10:15:15 2002
@@ -6,9 +6,11 @@
PGM = $(ARCH)/console.rel
-C_FILES = console.c
+C_FILES = console.c sci.c
C_O_FILES = $(C_FILES:%.c=$(ARCH)/%.o)
+H_FILES = sci.h
OBJS = $(C_O_FILES)
include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
diff -Nur rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/console/Makefile.in rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/console/Makefile.in
--- rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/console/Makefile.in Fri Jan 18 15:03:19 2002
+++ rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/console/Makefile.in Sun Feb 24 10:15:52 2002
@@ -101,9 +101,11 @@
+H_FILES = sci.h
OBJS = $(C_O_FILES)
@RTEMS_USE_GCC_TRUE at CFLAGS_DEFAULT = -g -Wall
diff -Nur rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/console/console.c rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/console/console.c
--- rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/console/console.c Fri May 25 09:28:46 2001
+++ rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/console/console.c Wed Feb 27 15:22:22 2002
@@ -1,397 +1,181 @@
- * This file contains the mrm console IO package.
+ * This file contains the generic console driver shell used
+ * by all console drivers using libchip.
- * COPYRIGHT (c) 1989-1999.
+ * This driver uses the termios pseudo driver.
+ * COPYRIGHT (c) 1989-1997.
* On-Line Applications Research Corporation (OAR).
+ * Copyright assigned to U.S. Government, 1994.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.OARcorp.com/rtems/license.html.
- * $Id: console.c,v 1.1 2001/05/25 16:28:46 joel Exp $
+ * $Id$
-#include <stdlib.h>
#include <bsp.h>
#include <rtems/libio.h>
+#include <termios.h>
+#include "sci.h"
+//#include "../../../../../../rtems/c/src/lib/libbsp/m68k/opti/console/duart.h"
+//#include "../../../../../../rtems/c/src/lib/libc/libio_.h"
-/* BUFFER_LENGTH must be 2^n for n=1, 2, 3, .... */
-#define BUFFER_LENGTH 256
-#define RTS_STOP_SIZE BUFFER_LENGTH-64
-#define RTS_START_SIZE 16
-char xmt_buf[BUFFER_LENGTH];
-char rcv_buf[BUFFER_LENGTH];
-/* in: last entry into the buffer; always on a valid character */
-/* out: points to the next character to be pull from the buffer */
-/* in+1=out => buffer empty */
-/* in+2=out => buffer full */
-struct UART_buf {
- char *offset;
- char *in;
- char *out;
-static volatile struct UART_buf xmt = { xmt_buf, (char *)0, (char *)1};
-static volatile struct UART_buf rcv = { rcv_buf, (char *)0, (char *)1};
-static volatile char _debug_flag = 0;
-#if 0
-#define SET_RTS(a) {*PORTF0 = (*PORTF0 & ~0x4) | ( (a)? 0 : 0x4); }
-#define GET_CTS (!(*PORTF0 & 0x2))
-#else
-#define SET_RTS(a) {;}
-#define GET_CTS 1
-#endif
-/* _catchSCIint, _catchCTSint, and _catchSPURIOUSint are the
- interrupt front-ends */
-extern void _catchSCIint();
-asm(" .text
- .align 2
- .globl _catchSCIint
-_catchSCIint:
- moveml %d0-%d7/%a0-%a6,%sp at - /* save registers */
- jbsr uart_interrupt
- moveml %sp at +,%d0-%d7/%a0-%a6
- rts
-extern void _catchCTSint();
-asm(" .text
- .align 2
- .globl _catchCTSint
-_catchCTSint:
- jbsr cts_interrupt
- rts
-extern void _catchSPURIOUSint();
-asm(" .text
- .align 2
- .globl _catchSPURIOUSint
-_catchSPURIOUSint:
- jbsr spurious_interrupt
- rts
-int _spurious_int_counter=0;
-/* note: cts uses int1. If it "bounces", a spurious interrupt is generated */
-void spurious_interrupt(void) {
- _spurious_int_counter++; /* there should never be alot of these */
-/* _fake_trap_1 will continue the UART interrupt (%sr *still*
- UART_ISR_LEVEL) as a trap #1 to enter the debugger */
-/* *****fix me; this is for 68000 w/jsr ram exception table ******* */
-asm(" .text
- .align 2
-_fake_trap_1:
- unlk %a6 /* clear interrupt frame */
- lea %sp@(4),%sp /* remove jbsr instruction */
- moveml %sp at +,%d0-%d7/%a0-%a6 /* pop registers */
- jmp (33*6-12) /* jump exception 1 */
-/* dispatch UART interrupt */
-void xmit_interrupt(void);
-void rcvr_interrupt(void);
-void _fake_trap_1(void);
-void uart_interrupt(void) {
- /* receiver status bits are cleared by a SCSR read followed
- by a SCDR read. transmitter status bits are cleared by
- a SCSR read followed by a SCDR write. */
- if ((*SCSR) & (TDRE | TC))
- xmit_interrupt();
- if ((*SCSR) & (RDRF))
- rcvr_interrupt();
- if (_debug_flag) {
- _debug_flag = 0; /* reset the flag */
- _fake_trap_1(); /* fake a trap #1 */
-/* transfer received character to the buffer */
-void rcvr_interrupt(void) {
- register char *a, c;
- register int length;
- while((*SCSR) & (RDRF)) {
- if ((c=*SCDR) == 0x1a) /* use ctl-z to reboot */
- reboot();
-/* else if (c == 0x03) { */ /* use ctl-c to enter debugger */
-/* _debug_flag = 1; */
-/* continue; */
- *(char *)((int)rcv.offset +(int)
- (a=(char *)(((int)rcv.in+1) & ((int)BUFFER_LENGTH-1)))) = c;
- if ((char *)(((int)rcv.in+2) & ((int)BUFFER_LENGTH-1)) != rcv.out)
- rcv.in=a;
- length = (BUFFER_LENGTH -1) & (
- ( ((int)rcv.out <= (int)rcv.in) ? 0 : BUFFER_LENGTH) - (int)rcv.out
- + (int)rcv.in + 1);
- if (length >= RTS_STOP_SIZE)
- SET_RTS(0);
-/* tranfer buffered characters to the UART */
-void xmit_interrupt(void) {
- register short int oldsr;
- _CPU_ISR_Disable( oldsr ); /* for when outbyte or flush calls */
- while ((*SCSR) & (TDRE)) {
- if ((char *)(((int)xmt.in+1) & ((int)BUFFER_LENGTH-1)) != xmt.out)
- /* xmit buffer not empty */
- if (GET_CTS) {
- /* send next char */
- *SCDR=*(char *)((int)xmt.offset+(int)xmt.out);
- xmt.out= (char *)(((int)xmt.out+1) & ((int)BUFFER_LENGTH-1));
- *SCCR1 = (*SCCR1 & ~(TIE | TCIE)) | (TIE);
- else {
- /* configue CTS interrupt and shutdown xmit interrupts */
- *SCCR1 &= ~(TIE | TCIE);
- *PFPAR |= 0x2;
- break;
- else {
- /* xmit buffer empty; shutdown interrupts */
- break;
- _CPU_ISR_Enable( oldsr );
-void cts_interrupt(void) {
- _CPU_ISR_Disable( oldsr ); /* for when outbyte calls */
- *PFPAR &= ~0x2;
-/* transfer character from the buffer */
-char inbyte(void) {
- register char a;
- while ((char *)(((int)rcv.in+1) & ((int)BUFFER_LENGTH-1))== rcv.out);
- a=*(char *)((int)rcv.offset+(int)rcv.out);
- rcv.out= (char *)(((int)rcv.out+1) & ((int)BUFFER_LENGTH-1));
- if (length < RTS_START_SIZE)
- SET_RTS(1);
- return (a);
-/* once room is avaliable in the buffer, transfer
- the character into the buffer and enable
- the xmtr interrupt */
-void outbyte(char c) {
- register char *a;
- while ((char *)(((int)xmt.in+2) & ((int)BUFFER_LENGTH-1)) == xmt.out);
- *(char *)((int)xmt.offset+(int)
- (a=(char *)(((int)xmt.in+1) & ((int)BUFFER_LENGTH-1))))=c;
- xmt.in=a;
- if (!(*SCCR1 & (TIE | TCIE)) && (!(*PFPAR & 0x2)) )
- /* if neither interrupts are running, */
- xmit_interrupt(); /* we need to restart the xmiter */
-void _UART_flush(void) {
- /* loop till xmt buffer empty. Works with interrupts disabled */
- while ((char *)(((int)xmt.in+1) & ((int)BUFFER_LENGTH-1)) != xmt.out)
- xmit_interrupt();
- /* loop till UART buffer empty */
- while ( (*SCSR & TC) == 0 );
-/* console_initialize
+/*PAGE
- * This routine initializes the console IO driver.
+ * console_open
- * Input parameters: NONE
+ * open a port as a termios console.
- * Output parameters: NONE
+ * the console is opened in bsp_postdriver_hook() in bsppost.c
- * Return values:
-void console_init()
- *QSMCR = ( SAM(QSM_IARB,0,IARB) );
- *QILR = ( SAM(ISRL_QSPI,4,ILQSPI) | SAM(ISRL_SCI,0,ILSCI) );
- *QIVR = ( SAM(EFI_QIVR,0,INTV) );
- *SCCR0 = ( (int)( SYS_CLOCK/SCI_BAUD/32.0+0.5 ) & 0x1fff );
- *SCCR1 = ( RIE | TE | RE );
- set_vector(_catchSPURIOUSint, EFI_SPINT, 1);
- set_vector(_catchSCIint, EFI_QIVR, 1);
- /* set_vector(_catchCTSint, EFI_INT1, 1); */
-rtems_device_driver console_initialize(
- rtems_device_major_number major,
- rtems_device_minor_number minor,
- void *arg
- rtems_status_code status;
- status = rtems_io_register_name(
- "/dev/console",
- major,
- (rtems_device_minor_number) 0
- if (status != RTEMS_SUCCESSFUL)
- rtems_fatal_error_occurred(status);
- return RTEMS_SUCCESSFUL;
-/* is_character_ready
- * This routine returns TRUE if a character is available.
- * Return values:
-rtems_boolean is_character_ready(
- char *ch
- if ((char *)(((int)rcv.in+1) & ((int)BUFFER_LENGTH-1))== rcv.out)
- return(FALSE);
- else
- return(TRUE);
- * Open entry point
rtems_device_driver console_open(
void * arg
+ rtems_status_code status;
+ /* the console is opened three times at startup */
+ /* for standard input, output, and error */
+ /* Get correct callback structure for the device */
+ /* argument of FALSE gives us interrupt driven serial io */
+ /* argument of TRUE gives us polling based serial io */
+ /* SCI internal uart */
+ status = rtems_termios_open( major, minor, arg, SciGetTermiosHandlers( TRUE ) );
+ return status;
- * Close entry point
+/*PAGE
+ * console_close
+ * This routine closes a port that has been opened as console.
rtems_device_driver console_close(
void * arg
+ return rtems_termios_close (arg);
- * read bytes from the serial port. We only have stdin.
+/*PAGE
+ * console_read
+ * This routine uses the termios driver to read a character.
rtems_device_driver console_read(
void * arg
- rtems_libio_rw_args_t *rw_args;
- char *buffer;
- int maximum;
- int count;
- rw_args = (rtems_libio_rw_args_t *) arg;
- buffer = rw_args->buffer;
- maximum = rw_args->count;
- for (count = 0; count < maximum; count++) {
- buffer[ count ] = inbyte();
- if (buffer[ count ] == '\n' || buffer[ count ] == '\r') {
- buffer[ count++ ] = '\n';
- break;
- rw_args->bytes_moved = count;
- return (count >= 0) ? RTEMS_SUCCESSFUL : RTEMS_UNSATISFIED;
+ return rtems_termios_read (arg);
- * write bytes to the serial port. Stdout and stderr are the same.
+/*PAGE
+ * console_write
+ * this routine uses the termios driver to write a character.
rtems_device_driver console_write(
void * arg
- int count;
- int maximum;
- char *buffer;
- if ( buffer[ count ] == '\n') {
- outbyte('\r');
- outbyte( buffer[ count ] );
- rw_args->bytes_moved = maximum;
- return 0;
+ return rtems_termios_write (arg);
- * IO Control entry point
+/*PAGE
+ * console_control
+ * this routine uses the termios driver to process io
rtems_device_driver console_control(
void * arg
+ return rtems_termios_ioctl (arg);
+/*PAGE
+ * console_initialize
+ * Routine called to initialize the console device driver.
+rtems_device_driver console_initialize(
+ rtems_device_major_number major,
+ rtems_device_minor_number minor_arg,
+ void *arg
+ * initialize the termio interface.
+ rtems_termios_initialize();
+ * register the SCI device name for termios
+ * do this over in the sci driver init routine?
+ status = rtems_io_register_name( "/dev/sci", major, 0 );
+ if (status != RTEMS_SUCCESSFUL)
+ rtems_fatal_error_occurred(status);
+ * Link the uart device to the console device
+#if 1
+ status = rtems_io_register_name( "/dev/console", major, 0 );
+#else
+ if ( link( "/dev/sci", "/dev/console") < 0 )
+ rtems_fatal_error_occurred( RTEMS_IO_ERROR );
+#endif
+ * Console Initialize Succesful
diff -Nur rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/console/sci.c rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/console/sci.c
--- rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/console/sci.c Wed Dec 31 16:00:00 1969
+++ rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/console/sci.c Thu Feb 28 11:08:19 2002
@@ -0,0 +1,1660 @@
+* File: sci.c
+* Desc: This file contains the console IO routines for the SCI port.
+* There are two interfaces in this module. One is for the rtems
+* termios/console code and the other is a device driver interface.
+* This module works together with the termio module which is
+* sometimes referred to as the "line disciplines" which implements
+* terminal i/o processing like tabs, backspaces, and newlines.
+* The rtems printf uses interrupt io and the rtems printk routine
+* uses polled io which is better for debugging.
+* Index: Documentation
+* Section A - Include Files
+* Section B - Manifest Constants
+* Section C - External Data
+* Section D - External Functions
+* Section E - Local Functions
+* Section F - Local Variables
+* Section G - A circular data buffer for rcv chars
+* Section H - RTEMS termios callbacks for the interrupt api
+* Section I - RTEMS termios callbacks for the polled api
+* Section 0 - Miscellaneous routines
+* Section 1 - Routines to manipulate the circular buffer
+* Section 2 - Interrupt based entry points for the termios module
+* Section 3 - Polling based entry points for the termios module
+* Section 4 - Device driver public api entry points
+* Section 5 - Hardware level routines
+* Section 6 - Testing and debugging code
+* Refer: Motorola QSM Reference Manual - Chapter 5 - SCI sub-module
+* Note: See bsp.h,confdefs.h,system.h for installing drivers into RTEMS.
+* $Id$
+* $Log$
+ Compiler Options for the incurably curious
+/opt/rtems/bin/m68k-rtems-gcc
+ --pipe # use pipes, not tmp files
+ -B../../../../../../../../opti/lib/ # where the library is
+ -specs bsp_specs # ???
+ -qrtems # ???
+ -g # add debugging info
+ -Wall # issue all warnings
+ -fasm # allow inline asm???
+ -DCONSOLE_SCI # for opti-r box/rev b proto
+ -mcpu32 # machine = motorola cpu 32
+ -c # compile, don't link
+ -O4 # max optimization
+ -fomit-frame-pointer # stack frames are optional
+ -o o-optimize/sci.o # the object file
+ ../../../../../../../../../rtems/c/src/lib/libbsp/m68k/opti/console/sci.c
+ Overview of serial port console terminal input/output
+ | app | | app |
+ | (printf,scanf,etc.) |
+ v |
+ | libc | |
+ | (open,close,read,write,ioctl) |
+ | /dev/console | /dev/sci
+ | (stdin,stdout,stderr) |
+ v v
+ | console | <---> | termios | <---> | sci |
+ | driver | | module | | driver |
+ v
+ | uart |
+ Section A - Include Files
+//#include <stdlib.h>
+#include <bsp.h>
+#include <rtems/libio.h>
+#include <libchip/serial.h>
+#include <libchip/sersupp.h>
+#include "sci.h"
+//#include "../misc/include/cpu332.h"
+ Section B - Manifest Constants
+#define SCI_MINOR 0 // minor device number
+// IMPORTANT - if the device driver api is opened, it means the sci is being
+// used for direct hardware access, so other users (like termios) get ignored
+#define DRIVER_CLOSED 0 // the device driver api is closed
+#define DRIVER_OPENED 1 // the device driver api is opened
+// system clock definitions, i dont have documentation on this...
+#if 0 // Not needed, this is provided in mrm332.h
+#define XTAL 32768.0 // crystal frequency in Hz
+#define NUMB_W 0 // system clock parameters
+#define NUMB_X 1
+//efine NUMB_Y 0x38 // for 14.942 Mhz
+#define NUMB_Y 0x3F // for 16.777 Mhz
+#define SYS_CLOCK (XTAL * 4.0 * (NUMB_Y+1) * (1 << (2 * NUMB_W + NUMB_X)))
+#endif
+ Section C - External Data
+ Section D - External Functions
+void printf();
+void printk();
+#if 0 // Why are these here? They are defined in unistd.h
+unsigned16 open();
+unsigned16 close();
+unsigned16 read();
+unsigned16 write();
+unsigned16 ioctl();
+#endif
+ Section E - Local Functions
+void SCI_output_char(char c);
+rtems_isr SciIsr( rtems_vector_number vector ); // interrupt handler
+const rtems_termios_callbacks * SciGetTermiosHandlers( signed32 polled );
+rtems_device_driver SciInitialize (); // device driver api
+rtems_device_driver SciOpen (); // device driver api
+rtems_device_driver SciClose (); // device driver api
+rtems_device_driver SciRead (); // device driver api
+rtems_device_driver SciWrite (); // device driver api
+rtems_device_driver SciControl (); // device driver api
+signed32 SciInterruptOpen(); // termios api
+signed32 SciInterruptClose(); // termios api
+signed32 SciInterruptWrite(); // termios api
+signed32 SciSetAttributes(); // termios api
+signed32 SciPolledOpen(); // termios api
+signed32 SciPolledClose(); // termios api
+signed32 SciPolledRead(); // termios api
+signed32 SciPolledWrite(); // termios api
+static void SciSetBaud(unsigned32 rate); // hardware routine
+static void SciSetDataBits(unsigned16 bits); // hardware routine
+static void SciSetParity(unsigned16 parity); // hardware routine
+static void inline SciDisableAllInterrupts( void ); // hardware routine
+static void inline SciDisableTransmitInterrupts( void );// hardware routine
+static void inline SciDisableReceiveInterrupts( void ); // hardware routine
+static void inline SciEnableTransmitInterrupts( void ); // hardware routine
+static void inline SciEnableReceiveInterrupts( void ); // hardware routine
+static void inline SciDisableReceiver( void ); // hardware routine
+static void inline SciDisableTransmitter( void ); // hardware routine
+static void inline SciEnableReceiver( void ); // hardware routine
+static void inline SciEnableTransmitter( void ); // hardware routine
+void SciWriteCharWait ( unsigned8 ); // hardware routine
+void SciWriteCharNoWait( unsigned8 ); // hardware routine
+unsigned8 inline SciCharAvailable( void ); // hardware routine
+unsigned8 inline SciReadCharWait( void ); // hardware routine
+unsigned8 inline SciReadCharNoWait( void ); // hardware routine
+void SciSendBreak( void ); // test routine
+static signed8 SciRcvBufGetChar(); // circular rcv buf
+static void SciRcvBufPutChar( unsigned8 ); // circular rcv buf
+//atic void SciRcvBufFlush( void ); // circular rcv buf
+void SciUnitTest(); // test routine
+void SciPrintStats(); // test routine
+ Section F - Local Variables
+static struct rtems_termios_tty *SciTermioTty;
+static unsigned8 SciInited = 0; // has the driver been inited
+static unsigned8 SciOpened; // has the driver been opened
+static unsigned8 SciMajor; // major device number
+static unsigned16 SciBaud; // current value in baud register
+static unsigned32 SciBytesIn = 0; // bytes received
+static unsigned32 SciBytesOut = 0; // bytes transmitted
+static unsigned32 SciErrorsParity = 0; // error counter
+static unsigned32 SciErrorsNoise = 0; // error counter
+static unsigned32 SciErrorsFraming = 0; // error counter
+static unsigned32 SciErrorsOverrun = 0; // error counter
+#if defined(CONSOLE_SCI)
+// this is what rtems printk uses to do polling based output
+BSP_output_char_function_type BSP_output_char = SCI_output_char;
+BSP_polling_getchar_function_type BSP_poll_char = NULL;
+#endif
+// cvs id string so you can use the unix ident command on the object
+#ifdef ID_STRINGS
+static const char SciIdent[]="$Id$";
+#endif
+ Section G - A circular buffer for rcv chars when the driver interface is used.
+// it is trivial to wrap your buffer pointers when size is a power of two
+#define SCI_RCV_BUF_SIZE 256 // must be a power of 2 !!!
+// if someone opens the sci device using the device driver interface,
+// then the receive data interrupt handler will put characters in this buffer
+// instead of sending them up to the termios module for the console
+static unsigned8 SciRcvBuffer[SCI_RCV_BUF_SIZE];
+static unsigned8 SciRcvBufPutIndex = 0; // array index to put in next char
+static unsigned8 SciRcvBufGetIndex = 0; // array index to take out next char
+static unsigned8 SciRcvBufCount = 0; // how many bytes are in the buffer
+ Section H - RTEMS termios callbacks for the interrupt version of the driver
+static const rtems_termios_callbacks SciInterruptCallbacks =
+ SciInterruptOpen, // first open
+ SciInterruptClose, // last close
+ NULL, // polled read (not required)
+ SciInterruptWrite, // write
+ SciSetAttributes, // set attributes
+ NULL, // stop remote xmit
+ NULL, // start remote xmit
+ TRUE // output uses interrupts
+ Section I - RTEMS termios callbacks for the polled version of the driver
+static const rtems_termios_callbacks SciPolledCallbacks =
+ SciPolledOpen, // first open
+ SciPolledClose, // last close
+ SciPolledRead, // polled read
+ SciPolledWrite, // write
+ FALSE // output uses interrupts
+// SECTION 0
+// MISCELLANEOUS ROUTINES
+* Func: SCI_output_char
+* Desc: used by rtems printk function to send a char to the uart
+* Inputs: the character to transmit
+* Outputs: none
+* Errors: none
+* Scope: public
+// ( minor device number, pointer to the character, length )
+ SciPolledWrite( SCI_MINOR, &c, 1);
+ return;
+* Func: SciGetTermiosHandlers
+* Desc: returns a pointer to the table of serial io functions
+* this is called from console_open with polled set to false
+* Inputs: flag indicating whether we want polled or interrupt driven io
+* Outputs: pointer to function table
+* Errors: none
+* Scope: public
+ if ( polled )
+ return &SciPolledCallbacks; // polling based
+ else
+ return &SciInterruptCallbacks; // interrupt driven
+* Func: SciIsr
+* Desc: interrupt handler for serial communications interface
+* Inputs: vector number - unused
+* Outputs: none
+* Errors: none
+* Scope: public API
+ unsigned8 ch;
+ if ( (*SCSR) & SCI_ERROR_PARITY ) SciErrorsParity ++;
+ if ( (*SCSR) & SCI_ERROR_FRAMING ) SciErrorsFraming ++;
+ if ( (*SCSR) & SCI_ERROR_NOISE ) SciErrorsNoise ++;
+ if ( (*SCSR) & SCI_ERROR_OVERRUN ) SciErrorsOverrun ++;
+ // see if it was a transmit interrupt
+ if ( (*SCSR) & SCI_XMTR_AVAILABLE ) // data reg empty, xmt complete
+ SciDisableTransmitInterrupts();
+ // tell termios module that the charcter was sent
+ // he will call us later to transmit more if there are any
+ if (rtems_termios_dequeue_characters( SciTermioTty, 1 ))
+ // there are more bytes to transmit so enable TX interrupt
+ SciEnableTransmitInterrupts();
+ // see if it was a receive interrupt
+ // on the sci uart we just get one character per interrupt
+ while ( SciCharAvailable() ) // char in data register?
+ ch = SciReadCharNoWait(); // get the char from the uart
+ // IMPORTANT!!!
+ // either send it to the termios module or keep it locally
+ if ( SciOpened == DRIVER_OPENED ) // the driver is open
+ SciRcvBufPutChar(ch); // keep it locally
+ else // put in termios buffer
+ rtems_termios_enqueue_raw_characters( SciTermioTty, &ch, 1 );
+ *SCSR &= SCI_CLEAR_RX_INT; // clear the interrupt
+// SECTION 1
+// ROUTINES TO MANIPULATE THE CIRCULAR BUFFER
+* Func: SciRcvBufGetChar
+* Desc: read a character from the circular buffer
+* make sure there is data before you call this!
+* Inputs: none
+* Outputs: the character or -1
+* Errors: none
+* Scope: private
+ rtems_interrupt_level level;
+ unsigned8 ch;
+ if ( SciRcvBufCount == 0 )
+ rtems_fatal_error_occurred(0xDEAD); // check the count first!
+ rtems_interrupt_disable( level ); // disable interrupts
+ ch = SciRcvBuffer[SciRcvBufGetIndex]; // get next byte
+ SciRcvBufGetIndex++; // bump the index
+ SciRcvBufGetIndex &= SCI_RCV_BUF_SIZE - 1; // and wrap it
+ SciRcvBufCount--; // decrement counter
+ rtems_interrupt_enable( level ); // restore interrupts
+ return ch; // return the char
+* Func: SciRcvBufPutChar
+* Desc: put a character into the rcv data circular buffer
+* Outputs: none
+* Errors: none
+* Scope: private
+static void SciRcvBufPutChar( unsigned8 ch )
+ if ( SciRcvBufCount == SCI_RCV_BUF_SIZE ) // is there room?
+ return; // no, throw it away
+ SciRcvBuffer[SciRcvBufPutIndex] = ch; // put it in the buf
+ SciRcvBufPutIndex++; // bump the index
+ SciRcvBufPutIndex &= SCI_RCV_BUF_SIZE - 1; // and wrap it
+ SciRcvBufCount++; // increment counter
+ return; // return
+* Func: SciRcvBufFlush
+* Desc: completely reset and clear the rcv buffer
+* Inputs: none
+* Outputs: none
+* Errors: none
+* Scope: private
+#if 0 // prevents compiler warning
+static void SciRcvBufFlush( void )
+ memset( SciRcvBuffer, 0, sizeof(SciRcvBuffer) );
+ SciRcvBufPutIndex = 0; // clear
+ SciRcvBufGetIndex = 0; // clear
+ SciRcvBufCount = 0; // clear
+ return; // return
+#endif
+// SECTION 2
+// INTERRUPT BASED ENTRY POINTS FOR THE TERMIOS MODULE
+* Func: SciInterruptOpen
+* Desc: open routine for the interrupt based device driver
+* Default state is 9600 baud, 8 bits, No parity, and 1 stop bit. ??
+* called from rtems_termios_open which is called from console_open
+* Inputs: major - device number
+* minor - device number
+* args - points to terminal info
+* Outputs: success/fail
+* Errors: none
+ signed32 major,
+ signed32 minor,
+ void *arg
+ rtems_libio_open_close_args_t * args = arg;
+ rtems_isr_entry old_vector;
+ if ( minor != SCI_MINOR ) // check minor device num
+ return -1;
+ if ( !args ) // must have args
+ return -1;
+ SciTermioTty = args->iop->data1; // save address of struct
+ SciDisableAllInterrupts(); // turn off sci interrupts
+ // THIS IS ACTUALLY A BAD THING - SETTING LINE PARAMETERS HERE
+ // IT SHOULD BE DONE THROUGH TCSETATTR() WHEN THE CONSOLE IS OPENED!!!
+// SciSetBaud(115200); // set the baud rate
+// SciSetBaud( 57600); // set the baud rate
+// SciSetBaud( 38400); // set the baud rate
+// SciSetBaud( 19200); // set the baud rate
+ SciSetBaud( 9600); // set the baud rate
+ SciSetParity(SCI_PARITY_NONE); // set parity to none
+ SciSetDataBits(SCI_8_DATA_BITS); // set data bits to 8
+ // Install our interrupt handler into RTEMS, where does 66 come from?
+ rtems_interrupt_catch( SciIsr, 66, &old_vector );
+ *QIVR = 66;
+ *QIVR &= 0xf8;
+ *QILR |= 0x06 & 0x07;
+ SciEnableTransmitter(); // enable the transmitter
+ SciEnableReceiver(); // enable the receiver
+ SciEnableReceiveInterrupts(); // enable rcv interrupts
+ return RTEMS_SUCCESSFUL;
+* Func: SciInterruptClose
+* Desc: close routine called by the termios module
+* args - unused
+* Errors: none
+* Scope: public - termio entry point
+ signed32 major,
+ signed32 minor,
+ void *arg
+* Func: SciInterruptWrite
+* Desc: writes data to the uart using transmit interrupts
+* Inputs: minor - device number
+* buf - points to the data
+* len - number of bytes to send
+* Errors: none
+ signed32 minor,
+ const char *buf,
+ signed32 len
+ // We are using interrupt driven output so termios only sends us
+ // one character at a time. The sci does not have a fifo.
+ if ( !len ) // no data?
+ return 0; // return error
+ if ( minor != SCI_MINOR ) // check the minor dev num
+ if ( SciOpened == DRIVER_OPENED ) // is the driver api open?
+ return 1; // yep, throw this away
+ SciWriteCharNoWait(*buf); // try to send a char
+ *SCSR &= SCI_CLEAR_TDRE; // clear tx data reg empty flag
+ SciEnableTransmitInterrupts(); // enable the tx interrupt
+ return 1; // return success
+* Func: SciSetAttributes
+* Desc: setup the uart based on the termios modules requests
+* t - pointer to the termios info struct
+* Outputs: none
+* Errors: none
+ signed32 minor,
+ const struct termios *t
+ unsigned32 baud_requested;
+ unsigned32 sci_rate = 0;
+ unsigned16 sci_parity = 0;
+ unsigned16 sci_databits = 0;
+ return -1; // return error
+ // if you look closely you will see this is the only thing we use
+ // set the baud rate
+ baud_requested = t->c_cflag & CBAUD; // baud rate
+ if (!baud_requested)
+ baud_requested = B9600; // default to 9600 baud
+ sci_rate = termios_baud_to_number( baud_requested );
+ // parity error detection
+ if (t->c_cflag & PARENB) // enable parity detection?
+ if (t->c_cflag & PARODD)
+ sci_parity = SCI_PARITY_ODD; // select odd parity
+ else
+ sci_parity = SCI_PARITY_EVEN; // select even parity
+ else
+ sci_parity = SCI_PARITY_NONE; // no parity, most common
+ // set the number of data bits, 8 is most common
+ if (t->c_cflag & CSIZE) // was it specified?
+ switch (t->c_cflag & CSIZE)
+ case CS8: sci_databits = SCI_8_DATA_BITS; break;
+ default : sci_databits = SCI_9_DATA_BITS; break;
+ else
+ sci_databits = SCI_8_DATA_BITS; // default to 8 data bits
+ // the number of stop bits; always 1 for SCI
+ if (t->c_cflag & CSTOPB)
+ // do nothing
+ // setup the hardware with these serial port parameters
+ SciSetBaud(sci_rate); // set the baud rate
+ SciSetParity(sci_parity); // set the parity type
+ SciSetDataBits(sci_databits); // set the data bits
+// SECTION 3
+// POLLING BASED ENTRY POINTS FOR THE TERMIOS MODULE
+* Func: SciPolledOpen
+* Desc: open routine for the polled i/o version of the driver
+* args - points to terminal info struct
+* Errors: none
+* Scope: public - termios entry point
+ signed32 major,
+ signed32 minor,
+ void *arg
+ return -1;
+ return -1;
+ SciTermioTty = args->iop->data1; // Store tty pointer
+ SciDisableAllInterrupts(); // don't generate interrupts
+ SciSetParity(SCI_PARITY_NONE); // set no parity
+ SciSetDataBits(SCI_8_DATA_BITS); // set 8 data bits
+ SciEnableTransmitter(); // enable the xmitter
+ SciEnableReceiver(); // enable the rcvr
+* Func: SciPolledClose
+* Desc: close routine for the device driver, same for both
+* args - unused
+* Errors: none
+* Scope: public termios API
+ signed32 major,
+ signed32 minor,
+ void *arg
+* Func: SciPolledRead
+* Desc: polling based read routine for the uart
+* Outputs: error or the character read
+* Errors: none
+ signed32 minor
+ if ( SciCharAvailable() ) // if a char is available
+ return SciReadCharNoWait(); // read the rx data register
+* Func: SciPolledWrite
+* Desc: writes out characters in polled mode, waiting for the uart
+* check in console_open, but we only seem to use interrupt mode
+* len - how many bytes
+* Outputs: error or number of bytes written
+* Errors: none
+ signed32 minor,
+ const char *buf,
+ signed32 len
+ signed32 written = 0;
+ return -1;
+ return -1; // toss the data
+ // send each byte in the string out the port
+ while ( written < len )
+ SciWriteCharWait(*buf++); // send a byte
+ written++; // increment counter
+ return written; // return count
+// SECTION 4
+// DEVICE DRIVER PUBLIC API ENTRY POINTS
+* Func: SciInit
+* Desc: Initialize the lasers device driver and hardware
+* Inputs: major - the major device number which is assigned by rtems
+* minor - the minor device number which is undefined at this point
+* arg - ?????
+* Outputs: RTEMS_SUCCESSFUL
+* Errors: None.
+ rtems_device_minor_number minor,
+ void * arg
+//printk("%s\r\n", __FUNCTION__);
+ // register the SCI device name for termios console i/o
+ // this is done over in console.c which doesn't seem exactly right
+ // but there were problems doing it here...
+// status = rtems_io_register_name( "/dev/sci", major, 0 );
+// if (status != RTEMS_SUCCESSFUL)
+// rtems_fatal_error_occurred(status);
+ SciMajor = major; // save the rtems major number
+ SciOpened = DRIVER_CLOSED; // initial state is closed
+ // if you have an interrupt handler, install it here
+ SciInited = 1; // set the inited flag
+* Func: SciOpen
+* Desc: device driver open routine
+* you must open a device before you can anything else
+* only one process can have the device opened at a time
+* you could look at the task id to restrict access if you want
+* Inputs: major - the major device number assigned by rtems
+* minor - the minor device number assigned by us
+* arg - ?????
+* Outputs: see below
+* Errors: none
+ void * arg
+//printk("%s major=%d minor=%d\r\n", __FUNCTION__,major,minor);
+ if (SciInited == 0) // must be initialized first!
+ return RTEMS_NOT_CONFIGURED;
+ if (minor != SCI_MINOR)
+ return RTEMS_INVALID_NAME; // verify minor number
+ if (SciOpened == DRIVER_OPENED)
+ return RTEMS_RESOURCE_IN_USE; // already opened!
+ SciOpened = DRIVER_OPENED; // set the opened flag
+* Func: SciClose
+* Desc: device driver close routine
+* the device must be opened before you can close it
+* the device must be closed before someone (else) can open it
+* arg - ?????
+* Errors: none
+ void * arg
+ return RTEMS_INVALID_NAME; // check the minor number
+ if (SciOpened != DRIVER_OPENED)
+ return RTEMS_INCORRECT_STATE; // must be opened first
+ SciOpened = DRIVER_CLOSED; // set the flag
+* Func: SciRead
+* Desc: device driver read routine
+* this function is not meaningful for the laser devices
+* arg - read/write arguments
+* Errors: none
+ void *arg
+ rtems_libio_rw_args_t *rw_args; // ptr to argument struct
+ unsigned8 *buffer;
+ unsigned16 length;
+ rw_args = (rtems_libio_rw_args_t *) arg; // arguments to read()
+ if (SciOpened == DRIVER_CLOSED)
+ buffer = rw_args->buffer; // points to user's buffer
+ length = rw_args->count; // how many bytes they want
+// *buffer = SciReadCharWait(); // wait for a character
+ // if there isn't a character available, wait until one shows up
+ // or the timeout period expires, which ever happens first
+ if ( SciRcvBufCount == 0 ) // no chars
+ // wait for someone to wake me up...
+ //rtems_task_wake_after(SciReadTimeout);
+ if ( SciRcvBufCount ) // any characters locally?
+ *buffer = SciRcvBufGetChar(); // get the character
+ rw_args->bytes_moved = 1; // how many we actually read
+* Func: SciWrite
+* Desc: device driver write routine
+* Errors: non3
+ void * arg
+ buffer = (unsigned8*)rw_args->buffer; // points to data
+ while (length--)
+ SciWriteCharWait(*buffer++); // send the bytes out
+* Func: SciControl
+* Desc: device driver control routine
+* see below for an example of how to use the ioctl interface
+* arg - io control args
+* Errors: none
+ void * arg
+ rtems_libio_ioctl_args_t *args = arg; // rtems arg struct
+ unsigned16 command; // the cmd to execute
+ unsigned16 unused; // maybe later
+ unsigned16 *ptr; // ptr to user data
+ // do some sanity checking
+ return RTEMS_INCORRECT_STATE; // must be open first
+ if (args == 0)
+ return RTEMS_INVALID_ADDRESS; // must have args
+ args->ioctl_return = -1; // assume an error
+ command = args->command; // get the command
+ ptr = args->buffer; // this is an address
+ unused = *ptr; // brightness
+ if (command == SCI_SEND_BREAK) // process the command
+ SciSendBreak(); // send break char
+ args->ioctl_return = 0; // return status
+// SECTION 5
+// HARDWARE LEVEL ROUTINES
+* Func: SciSetBaud
+* Inputs: baud rate
+* Outputs: none
+* Errors: none
+* Scope: private
+ unsigned16 value;
+ unsigned16 save_sccr1;
+// when you open the console you need to set the termio struct baud rate
+// it has a default value of 9600, when someone calls tcsetattr it reverts!
+ SciBaud = rate; // save the rate
+ // calculate the register value as a float and convert to an int
+ // set baud rate - you must define the system clock constant
+ // see efi332.h for an example
+ value = ( (unsigned16) ( SYS_CLOCK / rate / 32.0 + 0.5 ) & 0x1fff );
+ save_sccr1 = *SCCR1; // save register
+ // also turns off the xmtr and rcvr
+ *SCCR1 &= SCI_DISABLE_INT_ALL; // disable interrupts
+ *SCCR0 = value; // write the register
+ *SCCR1 = save_sccr1; // restore register
+ return;
+* Func: SciSetParity
+* Inputs: parity
+* Outputs: none
+* Errors: none
+* Scope: private
+ unsigned16 value;
+ value = *SCCR1; // get the register
+ if (parity == SCI_PARITY_ODD)
+ value |= SCI_PARITY_ENABLE; // parity enabled
+ value |= SCI_PARITY_ODD; // parity odd
+ else if (parity == SCI_PARITY_EVEN)
+ value &= ~SCI_PARITY_ODD; // parity even
+ else if (parity == SCI_PARITY_NONE)
+ value &= ~SCI_PARITY_ENABLE; // disabled, most common
+ /* else no changes */
+ *SCCR1 = value; // write the register
+ return;
+* Func: SciSetDataBits
+* Inputs: data bits
+* Outputs: none
+* Errors: none
+* Scope: private
+ unsigned16 value;
+ /* note - the parity setting affects the number of data bits */
+ if (bits == SCI_9_DATA_BITS)
+ value |= SCI_9_DATA_BITS; // 9 data bits
+ else if (bits == SCI_8_DATA_BITS)
+ value &= SCI_8_DATA_BITS; // 8 data bits
+ return;
+* Func: SciDisableAllInterrupts
+* Func: SciEnableTransmitInterrupts
+* Func: SciEnableReceiveInterrupts
+* Desc: handles generation of interrupts by the sci module
+* Inputs: none
+* Outputs: none
+* Errors: none
+* Scope: private
+ // this also turns off the xmtr and rcvr
+ *SCCR1 |= SCI_ENABLE_INT_RX;
+ *SCCR1 &= SCI_DISABLE_INT_RX;
+ *SCCR1 |= SCI_ENABLE_INT_TX;
+ *SCCR1 &= SCI_DISABLE_INT_TX;
+* Func: SciEnableTransmitter, SciDisableTransmitter
+* Func: SciEnableReceiver, SciDisableReceiver
+* Desc: turns the transmitter and receiver on and off
+* Inputs: none
+* Outputs: none
+* Errors: none
+* Scope: private
+ *SCCR1 |= SCI_ENABLE_XMTR;
+ *SCCR1 &= SCI_DISABLE_XMTR;
+ *SCCR1 |= SCI_ENABLE_RCVR;
+ *SCCR1 &= SCI_DISABLE_RCVR;
+* Func: SciWriteCharWait
+* Desc: wait for room in the fifo and then put a char in
+* Inputs: a byte to send
+* Outputs: none
+* Errors: none
+* Scope: public
+void SciWriteCharWait(unsigned8 c)
+ // poll the fifo, waiting for room for another character
+ while ( ( *SCSR & SCI_XMTR_AVAILABLE ) == 0 )
+ /* Either we are writing to the fifo faster than
+ * the uart can clock bytes out onto the cable,
+ * or we are in flow control (actually no, we
+ * are ignoring flow control from the other end).
+ * In the first case, higher baud rates will help.
+ *SCDR = c; // send the charcter
+ SciBytesOut++; // increment the counter
+ return;
+* Func: SciWriteCharNoWait
+* Desc: if no room in the fifo throw the char on the floor
+* Outputs: none
+* Errors: none
+* Scope: public
+void SciWriteCharNoWait(unsigned8 c)
+ if ( ( *SCSR & SCI_XMTR_AVAILABLE ) == 0 )
+ return; // no room, throw it away
+ *SCDR = c; // put the char in the fifo
+ return;
+* Func: SciReadCharWait
+* Desc: read a character, waiting for one to show up, if need be
+* Inputs: none
+* Outputs: a character
+* Errors: none
+* Scope: public
+ unsigned8 ch;
+ while ( SciCharAvailable() == 0 ) // anything there?
+ // do nothing
+ // if you have rcv ints enabled, then the isr will probably
+ // get the character before you will unless you turn off ints
+ // ie polling and ints don't mix that well
+ ch = *SCDR; // get the charcter
+ SciBytesIn++; // increment the counter
+* Func: SciReadCharNoWait
+* Desc: try to get a char but dont wait for one
+* Inputs: none
+* Outputs: a character or -1 if none
+* Errors: none
+* Scope: public
+ unsigned8 ch;
+ if ( SciCharAvailable() == 0 ) // anything there?
+ return -1;
+ ch = *SCDR; // get the character
+* Func: SciCharAvailable
+* Desc: is there a receive character in the data register
+* Inputs: none
+* Outputs: false if no char available, else true
+* Errors: none
+* Scope: public
+ return ( *SCSR & SCI_RCVR_READY ); // char in data register?
+* Func: SciSendBreak
+* Desc: send 1 or tow breaks (all zero bits)
+* Inputs: none
+* Outputs: none
+* Errors: none
+* Scope: public
+ // From the Motorola QSM reference manual -
+ // "if SBK is toggled by writing it first to a one and then immediately
+ // to a zero (in less than one serial frame interval), the transmitter
+ // sends only one or two break frames before reverting to mark (idle)
+ // or before commencing to send more data"
+ *SCCR1 |= SCI_SEND_BREAK; // set the bit
+ *SCCR1 &= ~SCI_SEND_BREAK; // clear the bit
+ return;
+// SECTION 6
+// TEST CODE
+* Func: SciUnitTest
+* Desc: test the device driver
+* Inputs: nothing
+* Outputs: nothing
+* Scope: public
+#define O_RDWR LIBIO_FLAGS_READ_WRITE // dont like this but...
+void SciUnitTest()
+ unsigned8 byte; // a character
+ unsigned16 fd; // file descriptor for device
+ unsigned16 result; // result of ioctl
+ fd = open("/dev/sci",O_RDWR); // open the device
+printk("SCI open fd=%d\r\n",fd);
+ result = write(fd, "abcd\r\n", 6); // send a string
+printk("SCI write result=%d\r\n",result);
+ result = read(fd, &byte, 1); // read a byte
+printk("SCI read result=%d,byte=%x\r\n",result,byte);
+ return;
+* Func: SciPrintStats
+* Desc: print out some driver information
+* Inputs: nothing
+* Outputs: nothing
+* Scope: public
+void SciPrintStats ( void )
+ printf("\r\n");
+ printf( "SYS_CLOCK is %2.6f Mhz\r\n\n", SYS_CLOCK / 1000000.0 );
+ printf( "Current baud rate is %d bps or %d cps\r\n\n", SciBaud, SciBaud / 10 );
+ printf( "SCI Uart chars in %8d\r\n", SciBytesIn );
+ printf( "SCI Uart chars out %8d\r\n", SciBytesOut );
+ printf( "SCI Uart framing errors %8d\r\n", SciErrorsFraming );
+ printf( "SCI Uart parity errors %8d\r\n", SciErrorsParity );
+ printf( "SCI Uart overrun errors %8d\r\n", SciErrorsOverrun );
+ printf( "SCI Uart noise errors %8d\r\n", SciErrorsNoise );
+ return;
diff -Nur rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/console/sci.h rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/console/sci.h
--- rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/console/sci.h Wed Dec 31 16:00:00 1969
+++ rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/console/sci.h Mon Jan 21 08:52:56 2002
@@ -0,0 +1,245 @@
+* File: sci.h
+* Desc: This is the include file for the serial communications interface.
+* $Id$
+#ifndef _sci_h_
+#define _sci_h_
+ IOCTL commands for the sci driver.
+ I'm still working on these...
+#define SCI_IOCTL_PARITY_NONE 0x00 // no parity bit after the data bits
+#define SCI_IOCTL_PARITY_ODD 0x01 // parity bit added after data bits
+#define SCI_IOCTL_PARITY_EVEN 0x02 // parity bit added after data bits
+#define SCI_IOCTL_PARITY_MARK 0x03 // parity bit is lo, -12 volts, logical 1
+#define SCI_IOCTL_PARITY_SPACE 0x04 // parity bit is hi, +12 volts, logical 0
+#define SCI_IOCTL_PARITY_FORCED_ON 0x03 // parity bit is forced hi or lo
+#define SCI_IOCTL_PARITY_FORCED_OFF 0x04 // parity bit is forced hi or lo
+#define SCI_IOCTL_BAUD_RATE 0x20 // set the baud rate, arg is baud
+#define SCI_IOCTL_DATA_BITS 0x30 // set the data bits, arg is # bits
+#define SCI_IOCTL_STOP_BITS_1 0x40 // 1 stop bit after char frame
+#define SCI_IOCTL_STOP_BITS_2 0x41 // 2 stop bit after char frame
+#define SCI_IOCTL_MODE_NORMAL 0x50 // normal operating mode
+#define SCI_IOCTL_MODE_LOOP 0x51 // internal loopback mode
+#define SCI_IOCTL_FLOW_NONE 0x60 // no flow control
+#define SCI_IOCTL_FLOW_RTS_CTS 0x61 // hardware flow control
+#define SCI_IOCTL_SEND_BREAK 0x70 // send an rs-232 break
+#define SCI_IOCTL_MODE_1200 0x80 // 1200,n,8,1 download mode
+#define SCI_IOCTL_MODE_9600 0x81 // 9600,n,8,1 download mode
+#define SCI_IOCTL_MODE_9_BIT 0x82 // 9600,forced,8,1 command mode
+ SCI Registers
+// SCI Control Register 0 (SCCR0) $FFFC08
+// 8 4 2 1 - 8 4 2 1 - 8 4 2 1 - 8 4 2 1
+// | | | | | | | | | | | | | | | +----- 0 baud rate divisor
+// | | | | | | | | | | | | | | +------- 1 baud rate divisor
+// | | | | | | | | | | | | | +--------- 2 baud rate divisor
+// | | | | | | | | | | | | +----------- 3 baud rate divisor
+// | | | | | | | | | | | +--------------- 4 baud rate divisor
+// | | | | | | | | | | +----------------- 5 baud rate divisor
+// | | | | | | | | | +------------------- 6 baud rate divisor
+// | | | | | | | | +--------------------- 7 baud rate divisor
+// | | | | | | | +------------------------- 8 baud rate divisor
+// | | | | | | +--------------------------- 9 baud rate divisor
+// | | | | | +----------------------------- 10 baud rate divisor
+// | | | | +------------------------------- 11 baud rate divisor
+// | | | +----------------------------------- 12 baud rate divisor
+// | | +------------------------------------- 13 unused
+// | +--------------------------------------- 14 unused
+// +----------------------------------------- 15 unused
+// 0 0 0 0 - 0 0 0 0 - 0 0 0 0 - 0 1 0 0 reset value - (64k baud?)
+#define SCI_BAUD_57_6K 9
+#define SCI_BAUD_38_4K 14
+#define SCI_BAUD_19_2K 27
+#define SCI_BAUD_9600 55
+#define SCI_BAUD_4800 109
+#define SCI_BAUD_2400 218
+#define SCI_BAUD_1200 437
+// SCI Control Register 1 (SCCR1) $FFFC0A
+// | | | | | | | | | | | | | | | +----- 0 send a break
+// | | | | | | | | | | | | | | +------- 1 rcvr wakeup mode
+// | | | | | | | | | | | | | +--------- 2 rcvr enable
+// | | | | | | | | | | | | +----------- 3 xmtr enable
+// | | | | | | | | | | | +--------------- 4 idle line intr enable
+// | | | | | | | | | | +----------------- 5 rcvr intr enable
+// | | | | | | | | | +------------------- 6 xmit complete intr enable
+// | | | | | | | | +--------------------- 7 xmtr intr enable
+// | | | | | | | +------------------------- 8 wakeup on address mark
+// | | | | | | +--------------------------- 9 mode 1=9 bits, 0=8 bits
+// | | | | | +----------------------------- 10 parity enable 1=on, 0=off
+// | | | | +------------------------------- 11 parity type 1=odd, 0=even
+// | | | +----------------------------------- 12 idle line select
+// | | +------------------------------------- 13 wired-or mode
+// | +--------------------------------------- 14 loop mode
+// 0 0 0 0 - 0 0 0 0 - 0 0 0 0 - 0 0 0 0 reset value
+#define SCI_SEND_BREAK 0x0001 // 0000-0000-0000-0001
+#define SCI_RCVR_WAKEUP 0x0002 // 0000-0000-0000-0010
+#define SCI_ENABLE_RCVR 0x0004 // 0000-0000-0000-0100
+#define SCI_ENABLE_XMTR 0x0008 // 0000-0000-0000-1000
+#define SCI_DISABLE_RCVR 0xFFFB // 1111-1111-1111-1011
+#define SCI_DISABLE_XMTR 0xFFF7 // 1111-1111-1111-0111
+#define SCI_ENABLE_INT_IDLE 0x0010 // 0000-0000-0001-0000
+#define SCI_ENABLE_INT_RX 0x0020 // 0000-0000-0010-0000
+#define SCI_ENABLE_INT_TX_DONE 0x0040 // 0000-0000-0100-0000
+#define SCI_ENABLE_INT_TX 0x0080 // 0000-0000-1000-0000
+#define SCI_DISABLE_INT_ALL 0xFF00 // 1111-1111-0000-0000 ???
+#define SCI_DISABLE_INT_RX 0xFFDF // 1111-1111-1101-1111
+#define SCI_CLEAR_RX_INT 0xFFBF // 1111-1111-1011-1111
+#define SCI_DISABLE_INT_TX 0xFF7F // 1111-1111-0111-1111
+#define SCI_CLEAR_TDRE 0xFEFF // 1111-1110-1111-1111
+#define SCI_RCVR_WAKE_ON_MARK 0x0100 // 0000-0001-0000-0000
+#define SCI_9_DATA_BITS 0x0200 // 0000-0010-0000-0000
+#define SCI_PARITY_ENABLE 0x0400 // 0000-0100-0000-0000
+#define SCI_PARITY_ODD 0x0800 // 0000-1000-0000-0000
+#define SCI_RCVR_WAKE_ON_IDLE 0xFEFF // 1111-1110-1111-1111
+#define SCI_8_DATA_BITS 0xFDFF // 1111-1101-1111-1111
+#define SCI_PARITY_DISABLE 0xFBFF // 1111-1011-1111-1111
+#define SCI_PARITY_EVEN 0xF7FF // 1111-0111-1111-1111
+#define SCI_PARITY_NONE 0xF3FF // 1111-0011-1111-1111
+#define SCI_IDLE_LINE_LONG 0x1000 // 0001-0000-0000-0000
+#define SCI_TXD_OPEN_DRAIN 0x2000 // 0010-0000-0000-0000
+#define SCI_LOOPBACK_MODE 0x4000 // 0100-0000-0000-0000
+#define SCI_SCCR1_UNUSED 0x8000 // 1000-0000-0000-0000
+// SCI Status Register (SCSR) $FFFC0C
+// | | | | | | | | | | | | | | | +----- 0 PF - parity error
+// | | | | | | | | | | | | | | +------- 1 FE - framing error
+// | | | | | | | | | | | | | +--------- 2 NF - noise flag
+// | | | | | | | | | | | | +----------- 3 OR - overrun flag
+// | | | | | | | | | | | +--------------- 4 IDLE - idle line detected
+// | | | | | | | | | | +----------------- 5 RAF - rcvr active flag
+// | | | | | | | | | +------------------- 6 RDRF - rcv data reg full
+// | | | | | | | | +--------------------- 7 TC - xmt complete flag
+// | | | | | | | +------------------------- 8 TDRE - xmt data reg empty
+// | | | | | | +--------------------------- 9 always zero
+// | | | | | +----------------------------- 10 always zero
+// | | | | +------------------------------- 11 always zero
+// | | | +----------------------------------- 12 always zero
+// | | +------------------------------------- 13 always zero
+// | +--------------------------------------- 14 always zero
+// +----------------------------------------- 15 always zero
+// 0 0 0 0 - 0 0 0 1 - 1 0 0 0 - 0 0 0 0 reset value
+#define SCI_ERROR_PARITY 0x0001 // 0000-0000-0000-0001
+#define SCI_ERROR_FRAMING 0x0002 // 0000-0000-0000-0010
+#define SCI_ERROR_NOISE 0x0004 // 0000-0000-0000-0100
+#define SCI_ERROR_OVERRUN 0x0008 // 0000-0000-0000-1000
+#define SCI_IDLE_LINE 0x0010 // 0000-0000-0001-0000
+#define SCI_RCVR_ACTIVE 0x0020 // 0000-0000-0010-0000
+#define SCI_RCVR_READY 0x0040 // 0000-0000-0100-0000
+#define SCI_XMTR_IDLE 0x0080 // 0000-0000-1000-0000
+#define SCI_XMTR_READY 0x0100 // 0000-0001-0000-0000
+#define SCI_XMTR_AVAILABLE 0x0180 // 0000-0001-1000-0000
+ Function prototypes
+#ifdef __cplusplus
+extern "C" {
+#endif
+// look at console_open to see how this is called
+/* SCI interrupt */
+//rtems_isr SciIsr( rtems_vector_number vector );
+//signed32 SciOpenPolled ( signed32 major, signed32 minor, void *arg );
+//signed32 SciOpenInterrupt ( signed32 major, signed32 minor, void *arg );
+//signed32 SciClose ( signed32 major, signed32 minor, void *arg );
+//signed32 SciWritePolled ( signed32 minor, const char *buf, signed32 len );
+//signed32 SciWriteInterrupt( signed32 minor, const char *buf, signed32 len );
+//signed32 SciReadPolled ( signed32 minor );
+//signed32 SciSetAttributes ( signed32 minor, const struct termios *t );
+#ifdef __cplusplus
+#endif
+#endif // _sci_h_
diff -Nur rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/include/bsp.h rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/include/bsp.h
--- rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/include/bsp.h Fri Sep 28 06:25:18 2001
+++ rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/include/bsp.h Sun Feb 24 14:16:11 2002
@@ -22,6 +22,7 @@
#include <bspopts.h>
+#include <rtems/bspIo.h>
#include <clockdrv.h>
#include <console.h>
#include <iosupp.h>
@@ -35,6 +36,7 @@
* - Interrupt stack space is not minimum if defined.
+#define CONSOLE_SCI
/* #define CONFIGURE_NUMBER_OF_TERMIOS_PORTS 2 */
/* #define CONFIGURE_INTERRUPT_STACK_MEMORY (TBD * 1024) */
@@ -102,7 +104,7 @@
#define RAW_PUTS(str) \
{ register char *ptr = str; \
- while (*ptr) outbyte(*ptr++); \
+ while (*ptr) SCI_output_char(*ptr++); \
#define RAW_PUTI(n) { \
@@ -111,7 +113,7 @@
RAW_PUTS("0x"); \
for (i=28;i>=0;i -= 4) { \
j = (n>>i) & 0xf; \
- outbyte( (j>9 ? j-10+'a' : j+'0') ); \
+ SCI_output_char( (j>9 ? j-10+'a' : j+'0') ); \
diff -Nur rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/include/mrm332.h rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/include/mrm332.h
--- rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/include/mrm332.h Fri May 25 09:28:46 2001
+++ rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/include/mrm332.h Sat Feb 23 19:18:16 2002
@@ -33,7 +33,7 @@
/* System Clock definitions */
#define XTAL 32768.0 /* crystal frequency in Hz */
-#if 0
+#if 1
/* Default MRM clock rate (8.388688 MHz) set by CPU32: */
#define MRM_W 0 /* system clock parameters */
#define MRM_X 0
@@ -47,7 +47,7 @@
#define MRM_Y 0x0f
#endif
-#if 1
+#if 0
/* 25.16582 MHz: */
#define MRM_W 1 /* system clock parameters */
#define MRM_X 1
@@ -60,6 +60,8 @@
/* macros/functions */
+#ifndef ASM
* This prototype really should have the noreturn attribute but
* that causes a warning. Not sure how to fix that.
@@ -68,4 +70,6 @@
static void reboot(void);
__inline__ static void reboot() {asm("trap #15; .word 0x0063");}
+#endif /* ASM */
#endif /* _MRM_H_ */
diff -Nur rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/spurious/spinit.c rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/spurious/spinit.c
--- rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/spurious/spinit.c Fri May 25 09:28:46 2001
+++ rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/spurious/spinit.c Thu Feb 28 07:41:03 2002
@@ -33,7 +33,7 @@
- int sp = 0;
+ //int sp = 0;
const char * const VectDescrip[] = {
_Spurious_Error_[0], _Spurious_Error_[0], _Spurious_Error_[1],
_Spurious_Error_[2], _Spurious_Error_[3], _Spurious_Error_[4],
@@ -58,11 +58,11 @@
_Spurious_Error_[27], _Spurious_Error_[27], _Spurious_Error_[27],
_Spurious_Error_[27], _Spurious_Error_[28]};
- asm volatile ( "movea.l %%sp,%0 " : "=a" (sp) : "0" (sp) );
+ //asm volatile ( "movea.l %%sp,%0 " : "=a" (sp) : "0" (sp) );
_CPU_ISR_Set_level( 7 );
- _UART_flush();
+ //_UART_flush();
+#if 0
RAW_PUTS("\n\rRTEMS: Spurious interrupt: ");
RAW_PUTS((char *)VectDescrip[( (vector>64) ? 64 : vector )]);
RAW_PUTS("\n\rRTEMS: Vector: ");
@@ -70,7 +70,7 @@
RAW_PUTS(" sp: ");
RAW_PUTI(sp);
RAW_PUTS("\n\r");
+#endif
bsp_cleanup();
/* BDM SIGEMT */
diff -Nur rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/start/Makefile.am rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/start/Makefile.am
--- rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/start/Makefile.am Fri May 25 10:35:09 2001
+++ rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/start/Makefile.am Tue Jan 22 20:23:54 2002
@@ -6,10 +6,10 @@
PGM = $(ARCH)/start.o
-C_FILES = start.c
-C_O_FILES = $(C_FILES:%.c=$(ARCH)/%.o)
+S_FILES = start.S
+S_O_FILES = $(S_FILES:%.S=$(ARCH)/%.o)
-OBJS = $(C_O_FILES)
+OBJS = $(S_O_FILES)
include $(top_srcdir)/../../../../../../automake/compile.am
@@ -28,6 +28,6 @@
.PRECIOUS: $(PGM)
-EXTRA_DIST = start.c
+EXTRA_DIST = start.S
include $(top_srcdir)/../../../../../../automake/local.am
diff -Nur rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/start/Makefile.in rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/start/Makefile.in
--- rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/start/Makefile.in Fri Jan 18 15:03:19 2002
+++ rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/start/Makefile.in Sun Feb 24 10:15:53 2002
@@ -101,10 +101,10 @@
-C_FILES = start.c
+S_FILES = start.S
@@ -260,7 +260,7 @@
TMPINSTALL_FILES = $(PROJECT_RELEASE)/lib$(MULTISUBDIR) $(PROJECT_RELEASE)/lib/start$(LIB_VARIANT).o
PROJECT_TOOLS = $(PROJECT_RELEASE)/build-tools
subdir = start
diff -Nur rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/start/start.S rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/start/start.S
--- rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/start/start.S Wed Dec 31 16:00:00 1969
+++ rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/start/start.S Thu Feb 28 07:34:55 2002
@@ -0,0 +1,151 @@
+ * $Id
+#include "mrm332.h"
+#include "asm.h"
+#include <sim.h>
+BEGIN_CODE
+ /* Put the header necessary for the modified CPU32bug to automatically
+ start up rtems: */
+#if 0
+.long 0xbeefbeef ;
+#endif
+.long 0 ;
+.long start ;
+.global start
+ start:
+ oriw #0x0700,sr
+ movel #end, d0
+ addl #_StackSize,d0
+ movel d0,sp
+ movel d0,a6
+ /* include in ram_init.S */
+ * Initalize the SIM module.
+ * The stack pointer is not usable until the RAM chip select lines
+ * are configured. The following code must remain inline.
+ /* Module Configuration Register */
+ /* see section(s) 3.1.3-3.1.6 of the SIM Reference Manual */
+ lea SIMCR, a0
+ movew #FRZSW,d0
+ oriw #SAM(0,8,SHEN),d0
+ oriw #(MM*SIM_MM),d0
+ oriw #SAM(SIM_IARB,0,IARB),d0
+ movew d0, a0@
+ jsr start_c /* Jump to the C startup code */
+END_CODE
+#if 0
+ /* Synthesizer Control Register */
+ /* see section(s) 4.8 */
+ /* end include in ram_init.S */
+ *SYNCR = (unsigned short int)
+ ( SAM(MRM_W,15,VCO) | SAM(0x0,14,PRESCALE) | SAM(MRM_Y,8,COUNTER) );
+ while (! (*SYNCR & SLOCK)); /* protect from clock overshoot */
+ ( SAM(MRM_W,15,VCO) | SAM(MRM_X,14,PRESCALE) | SAM(MRM_Y,8,COUNTER) );
+ /* System Protection Control Register */
+ /* !!! can only write to once after reset !!! */
+ /* see section 3.8.4 of the SIM Reference Manual */
+ *SYPCR = (unsigned char)( HME | BME );
+ /* Periodic Interrupr Control Register */
+ /* see section 3.8.2 of the SIM Reference Manual */
+ *PICR = (unsigned short int)
+ ( SAM(0,8,PIRQL) | SAM(MRM_PIV,0,PIV) );
+ /* ^^^ zero disables interrupt, don't enable here or ram_init will
+ be wrong. It's enabled below. */
+ /* Periodic Interrupt Timer Register */
+ /* see section 3.8.3 of the SIM Reference Manual */
+ *PITR = (unsigned short int)( SAM(0x09,0,PITM) );
+ /* 1.098mS interrupt, assuming 32.768 KHz input clock */
+ /* Port C Data */
+ /* load values before enabled */
+ *PORTC = (unsigned char) 0x0;
+ /* Port E and F Data Register */
+ /* see section 9 of the SIM Reference Manual */
+ *PORTE0 = (unsigned char) 0;
+ *PORTF0 = (unsigned char) 0;
+ /* Port E and F Data Direction Register */
+ *DDRE = (unsigned char) 0xff;
+ *DDRF = (unsigned char) 0xfd;
+ /* Port E and F Pin Assignment Register */
+ *PEPAR = (unsigned char) 0;
+ *PFPAR = (unsigned char) 0;
+ /* end of SIM initalization code */
+ * Initialize RAM by copying the .data section out of ROM (if
+ * needed) and "zero-ing" the .bss section.
+ register char *src = _etext;
+ register char *dst = _copy_start;
+ if (_copy_data_from_rom)
+ /* ROM has data at end of text; copy it. */
+ while (dst < _edata)
+ *dst++ = *src++;
+ /* Zero bss */
+ for (dst = _clear_start; dst< end; dst++)
+ *dst = 0;
+ * Initialize vector table.
+ m68k_isr_entry *monitors_vector_table;
+ m68k_get_vbr(monitors_vector_table);
+ M68Kvec[ 4 ] = monitors_vector_table[ 4 ]; /* breakpoints vector */
+ M68Kvec[ 9 ] = monitors_vector_table[ 9 ]; /* trace vector */
+ M68Kvec[ 31 ] = monitors_vector_table[ 31 ]; /* level 7 interrupt */
+ M68Kvec[ 47 ] = monitors_vector_table[ 47 ]; /* system call vector */
+ M68Kvec[ 66 ] = monitors_vector_table[ 66 ]; /* user defined */
+ m68k_set_vbr(&M68Kvec);
+ * Initalize the board.
+ Spurious_Initialize();
+ console_init();
+ * Execute main with arguments argc and agrv.
+ boot_card(1,__argv);
+ reboot();
+#endif
diff -Nur rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/start/start.c rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/start/start.c
--- rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/start/start.c Fri May 25 09:28:46 2001
+++ rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/start/start.c Wed Dec 31 16:00:00 1969
@@ -1,259 +0,0 @@
- * $Id
-#include <mrm332.h>
-#include <sim.h>
-#define __START_C__
-#include "bsp.h"
-m68k_isr_entry M68Kvec[256];
-m68k_isr_entry vectors[256];
-char * const __argv[]= {"main", ""};
-void boot_card(int argc, char * const argv[]);
- * This prototype really should have the noreturn attribute but
- * that causes a warning. Not sure how to fix that.
-/* void dumby_start () __attribute__ ((noreturn)); */
-void dumby_start ();
-void dumby_start() {
- /* Put the header necessary for the modified CPU32bug to automatically
- start up rtems: */
- asm volatile ( ".long 0xbeefbeef ;
- .long 0 ;
- .long start");
- /* We need to by-pass the link instruction since the RAM chip-
- select pins are not yet configured. */
- asm volatile ( ".global start ;
- start:");
- /* disable interrupts, copy CPU32bug vectors, load stack pointer */
- asm volatile ( "oriw #0x0700, %sr;
- movel #end, %d0;
- addl #_StackSize,%d0;
- movel %d0,%sp;
- movel %d0,%a6"
- /* include in ram_init.S */
- * Initalize the SIM module.
- * The stack pointer is not usable until the RAM chip select lines
- * are configured. The following code must remain inline.
- /* Module Configuration Register */
- /* see section(s) 3.1.3-3.1.6 of the SIM Reference Manual */
- *SIMCR = (unsigned short int)
- (FRZSW | SAM(0,8,SHEN) | (MM*SIM_MM) | SAM(SIM_IARB,0,IARB));
- /* Synthesizer Control Register */
- /* see section(s) 4.8 */
- /* end include in ram_init.S */
- *SYNCR = (unsigned short int)
- ( SAM(MRM_W,15,VCO) | SAM(0x0,14,PRESCALE) | SAM(MRM_Y,8,COUNTER) );
- while (! (*SYNCR & SLOCK)); /* protect from clock overshoot */
- ( SAM(MRM_W,15,VCO) | SAM(MRM_X,14,PRESCALE) | SAM(MRM_Y,8,COUNTER) );
- /* System Protection Control Register */
- /* !!! can only write to once after reset !!! */
- /* see section 3.8.4 of the SIM Reference Manual */
- *SYPCR = (unsigned char)( HME | BME );
- /* Periodic Interrupr Control Register */
- /* see section 3.8.2 of the SIM Reference Manual */
- *PICR = (unsigned short int)
- ( SAM(0,8,PIRQL) | SAM(MRM_PIV,0,PIV) );
- /* ^^^ zero disables interrupt, don't enable here or ram_init will
- be wrong. It's enabled below. */
- /* Periodic Interrupt Timer Register */
- /* see section 3.8.3 of the SIM Reference Manual */
- *PITR = (unsigned short int)( SAM(0x09,0,PITM) );
- /* 1.098mS interrupt, assuming 32.768 KHz input clock */
- /* Port C Data */
- /* load values before enabled */
- *PORTC = (unsigned char) 0x0;
-#if 0
- /* Don't touch these on MRM, they are set up by CPU32bug at boot time. */
- /* Chip-Select Base Address Register */
- /* see section 7 of the SIM Reference Manual */
- *CSBARBT = (unsigned short int)
- (((0x000000 >> 8)&0xfff8) | BS_512K ); /* 512k bytes located at 0x0000 */
- *CSBAR0 = (unsigned short int)
- (((0x000000 >> 8)&0xfff8) | BS_1M ); /* 1M bytes located at 0x0000 */
- *CSBAR1 = (unsigned short int)
- (((0x080000 >> 8)&0xfff8) | BS_256K ); /* 256k bytes located at 0x80000 */
- *CSBAR2 = (unsigned short int)
- *CSBAR3 = (unsigned short int)
- (((0x0C0000 >> 8)&0xfff8) | BS_256K ); /* 256k bytes located at 0xC0000 */
- *CSBAR4 = (unsigned short int)
- *CSBAR5 = (unsigned short int)
- (0xfff8 | BS_64K); /* AVEC interrupts */
-#if 0
-#ifdef EFI332_v040b
- *CSBAR6 = (unsigned short int)
- *CSBAR8 = (unsigned short int) /* PCMCIA IOCS */
- (((0x0c0000 >> 8)&0xfff8) | BS_64K ); /* 64k bytes located at 0xc0000 */
- *CSBAR9 = (unsigned short int) /* PCMCIA MEMCS */
- (((0x0D0000 >> 8)&0xfff8) | BS_64K ); /* 64k bytes located at 0xd0000 */
-#else /* EFI332_v040b */
- *CSBAR10 = (unsigned short int)
-#endif /* EFI332_v040b */
-#endif
- /* Chip-Select Options Registers */
-#ifdef FLASHWRITE
- *CSORBT = (unsigned short int)
- ( BothBytes | ReadWrite | SyncAS | WaitStates_0 | UserSupSpace );
-#else /* FLASHWRITE */
- ( BothBytes | ReadOnly | SyncAS | WaitStates_0 | UserSupSpace );
-#endif /* FLASHWRITE */
- *CSOR0 = (unsigned short int)
- ( BothBytes | ReadOnly | SyncAS | External | UserSupSpace );
- *CSOR1 = (unsigned short int)
- ( LowerByte | ReadWrite | SyncAS | FastTerm | UserSupSpace );
- *CSOR2 = (unsigned short int)
- ( UpperByte | ReadWrite | SyncAS | FastTerm | UserSupSpace );
- *CSOR3 = (unsigned short int)
- *CSOR4 = (unsigned short int)
- *CSOR5 = (unsigned short int)
- ( BothBytes | ReadWrite | SyncAS | CPUSpace | IPLevel_any | AVEC );
-#if 0
- *CSOR6 = (unsigned short int)
- *CSOR8 = (unsigned short int)
- ( BothBytes | ReadWrite | SyncAS | External | UserSupSpace );
- *CSOR9 = (unsigned short int)
- *CSOR10 = (unsigned short int)
-#endif
- /* Chip Select Pin Assignment Register 0 */
- *CSPAR0 = (unsigned short int)(
- SAM(DisOut,CS_5,0x3000) | /* AVEC (internally) */
- SAM(CS16bit,CS_4,0x0c00) | /* RAM UDS, bank2 */
- SAM(CS16bit,CS_3,0x0300) | /* RAM LDS, bank2 */
- SAM(CS16bit,CS_2,0x00c0)| /* RAM UDS, bank1 */
- SAM(CS16bit,CS_1,0x0030)| /* RAM LDS, bank1 */
- SAM(CS16bit,CS_0,0x000c)| /* W/!R */
- SAM(CS16bit,CSBOOT,0x0003) /* ROM CS */
- /* Chip Select Pin Assignment Register 1 */
- *CSPAR1 = (unsigned short int)(
- SAM(DisOut,CS_10,0x300)| /* ECLK */
- SAM(CS16bit,CS_9,0x0c0) | /* PCMCIA MEMCS */
- SAM(CS16bit,CS_8,0x030) | /* PCMCIA IOCS */
- SAM(DisOut,CS_7,0x00c) | /* PC4 */
- SAM(CS16bit,CS_6,0x003) /* ROM !OE */
- SAM(CS16bit,CS_10,0x300)| /* ROM !OE */
- SAM(DisOut,CS_9,0x0c0) | /* PC6 */
- SAM(DisOut,CS_8,0x030) | /* PC5 */
- SAM(DisOut,CS_6,0x003) /* PC3 */
-#endif /* Don't touch on MRM */
- /* Port E and F Data Register */
- /* see section 9 of the SIM Reference Manual */
- *PORTE0 = (unsigned char) 0;
- *PORTF0 = (unsigned char) 0;
- /* Port E and F Data Direction Register */
- *DDRE = (unsigned char) 0xff;
- *DDRF = (unsigned char) 0xfd;
- /* Port E and F Pin Assignment Register */
- *PEPAR = (unsigned char) 0;
- *PFPAR = (unsigned char) 0;
- /* end of SIM initalization code */
- * Initialize RAM by copying the .data section out of ROM (if
- * needed) and "zero-ing" the .bss section.
- register char *src = _etext;
- register char *dst = _copy_start;
- if (_copy_data_from_rom)
- /* ROM has data at end of text; copy it. */
- while (dst < _edata)
- *dst++ = *src++;
- /* Zero bss */
- for (dst = _clear_start; dst< end; dst++)
- *dst = 0;
- * Initialize vector table.
- m68k_isr_entry *monitors_vector_table;
- m68k_get_vbr(monitors_vector_table);
- M68Kvec[ 4 ] = monitors_vector_table[ 4 ]; /* breakpoints vector */
- M68Kvec[ 9 ] = monitors_vector_table[ 9 ]; /* trace vector */
- M68Kvec[ 31 ] = monitors_vector_table[ 31 ]; /* level 7 interrupt */
- M68Kvec[ 47 ] = monitors_vector_table[ 47 ]; /* system call vector */
- M68Kvec[ 66 ] = monitors_vector_table[ 66 ]; /* user defined */
- m68k_set_vbr(&M68Kvec);
- * Initalize the board.
- Spurious_Initialize();
- console_init();
- * Execute main with arguments argc and agrv.
- boot_card(1,__argv);
- reboot();
diff -Nur rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/startup/Makefile.am rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/startup/Makefile.am
--- rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/startup/Makefile.am Fri May 25 10:35:09 2001
+++ rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/startup/Makefile.am Tue Feb 12 14:56:25 2002
@@ -8,7 +8,7 @@
PGM = $(ARCH)/startup.rel
-C_FILES = bsplibc.c bsppost.c bspstart.c bspclean.c bootcard.c \
+C_FILES = start_c.c bsplibc.c bsppost.c bspstart.c bspclean.c bootcard.c \
m68kpretaskinghook.c main.c sbrk.c setvec.c gnatinstallhandler.c
diff -Nur rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/startup/Makefile.in rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/startup/Makefile.in
--- rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/startup/Makefile.in Fri Jan 18 15:03:19 2002
+++ rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/startup/Makefile.in Sun Feb 24 10:15:53 2002
@@ -102,7 +102,7 @@
diff -Nur rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/startup/bspclean.c rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/startup/bspclean.c
--- rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/startup/bspclean.c Fri May 25 09:28:46 2001
+++ rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/startup/bspclean.c Sun Feb 24 12:57:03 2002
@@ -23,5 +23,5 @@
/* interrupt driven stdio must be flushed */
- _UART_flush();
+ //_UART_flush();
diff -Nur rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/startup/linkcmds rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/startup/linkcmds
--- rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/startup/linkcmds Fri May 25 09:28:46 2001
+++ rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/startup/linkcmds Sat Feb 23 19:20:35 2002
@@ -34,10 +34,10 @@
* Declare some sizes.
_RamBase = DEFINED(_RamBase) ? _RamBase : 0x03000;
-_RamSize = DEFINED(_RamSize) ? _RamSize : 0x80000;
+_RamSize = DEFINED(_RamSize) ? _RamSize : 0x7d000;
_RamEnd = _RamBase + _RamSize;
_HeapSize = DEFINED(_HeapSize) ? _HeapSize : 0x10000;
-_StackSize = DEFINED(_StackSize) ? _StackSize : 0x1000;
+_StackSize = DEFINED(_StackSize) ? _StackSize : 0x2000;
MEMORY
diff -Nur rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/startup/start_c.c rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/startup/start_c.c
--- rtems-ss-20020118/c/src/lib/libbsp/m68k/mrm332/startup/start_c.c Wed Dec 31 16:00:00 1969
+++ rtems-ss-20020118-mike/c/src/lib/libbsp/m68k/mrm332/startup/start_c.c Thu Feb 28 12:04:58 2002
@@ -0,0 +1,124 @@
+ * $Id
+#include <mrm332.h>
+#include <sim.h>
+#define __START_C__
+#include "bsp.h"
+m68k_isr_entry M68Kvec[256];
+m68k_isr_entry vectors[256];
+char * const __argv[]= {"main", ""};
+void boot_card(int argc, char * const argv[]);
+ * This prototype really should have the noreturn attribute but
+ * that causes a warning. Not sure how to fix that.
+/* void dumby_start () __attribute__ ((noreturn)); */
+void start_c ();
+void start_c() {
+ /* Port C Data */
+ *dst++ = *src++;
+ /* Zero bss */
+ *dst = 0;
+ //console_init();
+ reboot();
