Fwd: RTEMS core: bad work with _Watchdog_* ?
Ilya Alexeev
ilya at continuum.ru
Wed Feb 6 13:10:26 UTC 2002
> I have been working offline with Ilya and sent him the suggestion
> to comment out the _ISR_Flash in src/watchdoginsert.c. Then he should
> have a finer grain view of the problem.
> --joel
Yes, after commenting out _ISR_Flash in src/watchdoginsert.c
my 'stress test' works fine.
There were a some my incorrectness in the previous letter:
the application worked good with _ISR_Disable/Enable around the
_Watchdog_Insert_ticks only.
Ilya.
