Stack size
Joe Novosel
jnovosel at broadcom.com
Wed Feb 6 20:15:43 UTC 2002
How do you configure RTEMS to listen for broadcast packets? This might
explain why bootp won't work on my platform.
Thanks,
Joe
On Wednesday 06 February 2002 09:44, Eric Norum wrote:
> Vinod Singh wrote:
> > Hi,
> > Can anybody tell me that what is the size of TCP/IP stack of freeBSD
> > ported by Rtems ? We need to know this size for porting on 68k motorola
> > proccessors.
> > Any pointer in this regard will be highly appreciated.
> > regards
> > Vinod
> The full FreeBSD network stack is quite large. Here are the sizes of an
> application with:
> text data bss dec hex filename
> 203152 5600 14160 222912 366c0 o-optimize/test.exe
> and without:
> 89568 3904 9712 103184 19310 o-optimize/test.exe
> the network stack. As well, the stack requires heap space. The actual
> amount depends on whether or not you want to receive broadcast packets,
> the amount of broadcast traffic on your network, how much traffic your
> node will receive/transmit, how many buffers are allocated by the
> network receiver task, etc. I'd say the absolute minimum would be 64
> kbytes and `enough' could be 512 kbytes or more.
> I'd like to do some research into extending the task both ways; Larger
> using the latest FreeBSD code including IPv6, IPsec, full termios
> drivers, etc ; Smaller using the LWip stack for smaller applications.
Joe Novosel
Test Engineer
Broadcom Corporation
Residential Broadband Unit
770-232-0018
