RTEMS sound device driver
Pattara Kiatisevi
pkiatisevi at student.ei.uni-stuttgart.de
Fri Feb 8 12:10:18 UTC 2002
Ok, thank you very much. But I can't download the snapshot version. The
link on the page said "ftp://oarcorp.com/pub/rtems/snapshots" hmm but I
think the DNS A record for oarcorp.com doesn't exist (?). Then I tried
ftp:/ftp.oarcorp.com/ but it said Anonymous FTP access denied (Hmm but a
few days ago I was just downloading sth. from here).
Pattara
BTW, http://www.oarcorp.com/ is not viewable by KDE's Konqueror web
browser, not sure if it is Konqueror problem or OAR's problem :)
On Fri, 8 Feb 2002, Chris Johns wrote:
> Pattara Kiatisevi wrote:
> > -And then how can I tell RTEMS to call this sound device driver when there
> > is access to /dev/dsp? Something to do with
> > #def CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE and I have to create my own
> > Device_drivers? (Hmm, but how and where? :) )
> I added to the RTEMS IO interface the ability to register and unregister
> device drivers at runtime. This means you do not need to have all
> drivers in the configuration table at compile time.
> This is useful when creating a set of base BSP libs that the application
> can extend without needing to open those tested libs up. Also in time
> when runtime loading of code happens .....
> This is only in the snapshots. Look in include/rtems/io.h.
> Chris Johns, cjohns at cybertec.com.au
