problems with "configure" options
Thomas Doerfler
Thomas.Doerfler at imd-systems.de
Tue Feb 12 12:59:24 UTC 2002
Hello Ralf,
thank you for the fast response. Now using the
prefix works fine.
But another problem seems to be there:
Installation of the "gen68360_040" BSP fails,
because some directories are not made in the
installation tree. I hope the attached file helps
to fix the corresponding errors.
After making 2 install directories by hand,
everyting works fine...
Bye,
Thomas.
> Am Die, 2002-02-12 um 08.40 schrieb Thomas Doerfler:
> > Hello Joel,
> > > This is a bug which was spotted in time to be fixed in
> > > the last snapshot.
> > I have downloaded ss-20020205 and tried it there
> > but it seems not be working there aswell...
> I fixed it on 2002-02-06 :)
> Patch enclosed below (Run bootstrap from the toplevel source-directory
> once after having applied the patch)
> Ralf
> Ralf Corsepius
> Forschungsinstitut fuer Anwendungsorientierte Wissensverarbeitung (FAW)
> Helmholtzstr. 16, 89081 Ulm, Germany Tel: +49/731/501-8690
> mailto:corsepiu at faw.uni-ulm.de FAX: +49/731/501-999
> http://www.faw.uni-ulm.de
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler Herbststrasse 8
D-82178 Puchheim Germany
email: Thomas.Doerfler at imd-systems.de
PGP public key available at: http://www.imd-
systems.de/pgp_key.htm
Making install in inline
gmake[5]: Entering directory `/usr/local/src/rtems/rtems-ss-20020205/tools/build
_gen68360_040/m68k-rtems/c/gen68360_040/exec/score/inline'
gmake[6]: Entering directory `/usr/local/src/rtems/rtems-ss-20020205/tools/build
gmake[6]: Nothing to be done for `install-exec-am'.
/bin/sh ../../../../../../../rtems-ss-20020205/c/src/exec/../../../mkinstalldirs
/opt/rtems/ss-20020205/m68k-rtems/gen68360_040/lib/include/rtems/score
/usr/bin/install -c -m 644 ../../../../../../../rtems-ss-20020205/c/src/exec/sc
ore/inline/rtems/score/address.inl /opt/rtems/ss-20020205/m68k-rtems/gen68360_04
0/lib/include/rtems/score/address.inl
ore/inline/rtems/score/chain.inl /opt/rtems/ss-20020205/m68k-rtems/gen68360_040/
lib/include/rtems/score/chain.inl
ore/inline/rtems/score/coremsg.inl /opt/rtems/ss-20020205/m68k-rtems/gen68360_04
0/lib/include/rtems/score/coremsg.inl
ore/inline/rtems/score/coremutex.inl /opt/rtems/ss-20020205/m68k-rtems/gen68360_
040/lib/include/rtems/score/coremutex.inl
ore/inline/rtems/score/coresem.inl /opt/rtems/ss-20020205/m68k-rtems/gen68360_04
0/lib/include/rtems/score/coresem.inl
ore/inline/rtems/score/heap.inl /opt/rtems/ss-20020205/m68k-rtems/gen68360_040/l
ib/include/rtems/score/heap.inl
ore/inline/rtems/score/isr.inl /opt/rtems/ss-20020205/m68k-rtems/gen68360_040/li
b/include/rtems/score/isr.inl
ore/inline/rtems/score/object.inl /opt/rtems/ss-20020205/m68k-rtems/gen68360_040
/lib/include/rtems/score/object.inl
ore/inline/rtems/score/priority.inl /opt/rtems/ss-20020205/m68k-rtems/gen68360_0
40/lib/include/rtems/score/priority.inl
ore/inline/rtems/score/stack.inl /opt/rtems/ss-20020205/m68k-rtems/gen68360_040/
lib/include/rtems/score/stack.inl
ore/inline/rtems/score/states.inl /opt/rtems/ss-20020205/m68k-rtems/gen68360_040
/lib/include/rtems/score/states.inl
ore/inline/rtems/score/sysstate.inl /opt/rtems/ss-20020205/m68k-rtems/gen68360_0
40/lib/include/rtems/score/sysstate.inl
ore/inline/rtems/score/thread.inl /opt/rtems/ss-20020205/m68k-rtems/gen68360_040
/lib/include/rtems/score/thread.inl
ore/inline/rtems/score/tod.inl /opt/rtems/ss-20020205/m68k-rtems/gen68360_040/li
b/include/rtems/score/tod.inl
ore/inline/rtems/score/tqdata.inl /opt/rtems/ss-20020205/m68k-rtems/gen68360_040
/lib/include/rtems/score/tqdata.inl
ore/inline/rtems/score/userext.inl /opt/rtems/ss-20020205/m68k-rtems/gen68360_04
0/lib/include/rtems/score/userext.inl
ore/inline/rtems/score/watchdog.inl /opt/rtems/ss-20020205/m68k-rtems/gen68360_0
40/lib/include/rtems/score/watchdog.inl
ore/inline/rtems/score/wkspace.inl /opt/rtems/ss-20020205/m68k-rtems/gen68360_04
0/lib/include/rtems/score/wkspace.inl
gmake[6]: Leaving directory `/usr/local/src/rtems/rtems-ss-20020205/tools/build_
gmake[5]: Leaving directory `/usr/local/src/rtems/rtems-ss-20020205/tools/build_
Making install in macros
_gen68360_040/m68k-rtems/c/gen68360_040/exec/score/macros'
Making install in cpu
_gen68360_040/m68k-rtems/c/gen68360_040/exec/score/cpu'
Making install in m68k
_gen68360_040/m68k-rtems/c/gen68360_040/exec/score/cpu/m68k'
gmake[7]: Entering directory `/usr/local/src/rtems/rtems-ss-20020205/tools/build
gmake[7]: Nothing to be done for `install-exec-am'.
/bin/sh ../../../../../../../../rtems-ss-20020205/c/src/exec/score/cpu/m68k/../.
./../../../../mkinstalldirs /opt/rtems/ss-20020205/m68k-rtems/gen68360_040/lib/i
nclude
/usr/bin/install -c -m 644 ../../../../../../../../rtems-ss-20020205/c/src/exec
/score/cpu/m68k/asm.h /opt/rtems/ss-20020205/m68k-rtems/gen68360_040/lib/include
/asm.h
/score/cpu/m68k/m68302.h /opt/rtems/ss-20020205/m68k-rtems/gen68360_040/lib/incl
ude/m68302.h
/score/cpu/m68k/m68360.h /opt/rtems/ss-20020205/m68k-rtems/gen68360_040/lib/incl
ude/m68360.h
/score/cpu/m68k/qsm.h /opt/rtems/ss-20020205/m68k-rtems/gen68360_040/lib/include
/qsm.h
/score/cpu/m68k/sim.h /opt/rtems/ss-20020205/m68k-rtems/gen68360_040/lib/include
/sim.h
nclude/rtems/score
/score/cpu/m68k/rtems/score/cpu.h /opt/rtems/ss-20020205/m68k-rtems/gen68360_040
/lib/include/rtems/score/rtems/score/cpu.h
/usr/bin/install: cannot create regular file `/opt/rtems/ss-20020205/m68k-rtems/
gen68360_040/lib/include/rtems/score/rtems/score/cpu.h': No such file or directo
ry
/score/cpu/m68k/rtems/score/m68k.h /opt/rtems/ss-20020205/m68k-rtems/gen68360_04
0/lib/include/rtems/score/rtems/score/m68k.h
gen68360_040/lib/include/rtems/score/rtems/score/m68k.h': No such file or direct
ory
/score/cpu/m68k/rtems/score/m68ktypes.h /opt/rtems/ss-20020205/m68k-rtems/gen683
60_040/lib/include/rtems/score/rtems/score/m68ktypes.h
gen68360_040/lib/include/rtems/score/rtems/score/m68ktypes.h': No such file or d
irectory
gmake[7]: *** [install-include_rtems_scoreHEADERS] Error 1
gmake[7]: Leaving directory `/usr/local/src/rtems/rtems-ss-20020205/tools/build_
gmake[6]: *** [install-am] Error 2
gmake[5]: *** [install-recursive] Error 1
gmake[4]: *** [install-recursive] Error 1
gmake[4]: Leaving directory `/usr/local/src/rtems/rtems-ss-20020205/tools/build_
gen68360_040/m68k-rtems/c/gen68360_040/exec/score'
gmake[3]: *** [install-recursive] Error 1
gmake[3]: Leaving directory `/usr/local/src/rtems/rtems-ss-20020205/tools/build_
gen68360_040/m68k-rtems/c/gen68360_040/exec'
gmake[2]: *** [install-recursive] Error 1
gmake[2]: Leaving directory `/usr/local/src/rtems/rtems-ss-20020205/tools/build_
gen68360_040/m68k-rtems/c/gen68360_040'
gmake[1]: *** [install-recursive] Error 1
gmake[1]: Leaving directory `/usr/local/src/rtems/rtems-ss-20020205/tools/build_
gen68360_040/m68k-rtems/c'
make: *** [install-recursive] Error 1
zerberus:/usr/local/src/rtems/rtems-ss-20020205/tools/build_gen68360_040 #
