posix problems with 0205 snapshot
Ralf Corsepius
corsepiu at faw.uni-ulm.de
Wed Feb 13 02:24:14 UTC 2002
Am Die, 2002-02-12 um 21.38 schrieb Chris Caudle:
> Has anyone tried the posix bsp with the 0205 snapshot yet?
Yes, there is a bug inside the configuration which only affects building
the posix-BSP, only (Fix attached below).
> I usually build the posix bsp first and run the sample tests just as a sanity
> check,
Well, IMHO, this check is of rather limited wealth, because the
posix-BSP internally is a rather different beast than the embedded
targets, and because large portions of RTEMS are not supported by the
posix-BSP.
Try the patch below. (Run bootstrap from the toplevel once after having
applied the patch).
Ralf
PS: Joel, IMO, the 0205 snapshot should be replaced, ASAP.
Index: c/src/exec/score/cpu/unix/configure.ac
RCS file: /usr1/CVS/rtems/c/src/exec/score/cpu/unix/configure.ac,v
retrieving revision 1.3
diff -u -r1.3 configure.ac
--- c/src/exec/score/cpu/unix/configure.ac 2002/01/24 14:13:14 1.3
+++ c/src/exec/score/cpu/unix/configure.ac 2002/02/10 19:42:18
@@ -32,16 +32,8 @@
## The code fragment below had been used in tools/cpu/unix/gensize.c.
## FIXME:
-## * The sun-stuff needs to be looked after.
## * The pad very likely is not necessary.
AC_CHECK_SIZEOF([CPU_CONTEXT],[],[
-#if defined(__sun__) && defined(__sparc__) && \
- defined(__unix__) && defined(__svr4__)
-#undef _POSIX_C_SOURCE
-#define _POSIX_C_SOURCE 3
-#undef __STRICT_ANSI__
-#endif
#include <setjmp.h>
