link() fails?
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Feb 27 14:47:23 UTC 2002
Mike Panetta wrote:
> I am in the middle of debugging the MRM332 BSP, and I am having a
> strange error. In console_init(), there is a piece of code that links
> /dev/sci to /dev/console. The link command is failing, saying links are
> not supported. What could cause this? The exact test in link.c that is
> failing is this: if ( !parent_loc.ops->link_h ), on line 72 of link.c.
> Does this clue anyone in? I think this may be all I need to resolve to
> get this BSP to work. Could I not be including some FS or FS option on
> the configure line when I am configuring RTEMS that would cause this?
> This has definatly been a fun ride (I had to debug and fix the BDM
> driver to even get this far ;), so it will be worth it to see this BSP
> working.
Symbolic links are not supported by the mini-IMFS which is the default
filesystem. An alternative to using a symlink is to register the
same major/minor combination with the 2nd name.
> Thanks,
> Mike
joel at OARcorp.com On-Line Applications Research
