Porting Rtems code( TCP/IP) stack on proprietary RTOs
Quality Quorum qqi at theworld.com
Sat Jan 5 13:33:25 UTC 2002
On Sat, 5 Jan 2002, Vinod Singh wrote:
> Hi,
> We  have to do Rtems code porting to some proprietary Real Time
> Operating system.
It is quite possible that you are violating RTEMS license,
Thanks,
Aleksey
> The following options are used for configuration
> rtems-4.5.0 code:
> "../rtems-4.5.0/configure  --target=i386-rtems --prefix=/usr/local
> --enable-cxx --enable-gmake-print-directory --disable-tests
> --disable-posix --enable-networking --enable-bare-cpu-cflags=pentium
> --enable-bare-cpu-model=pentium --enable-rtemsbsp=bare "
> The required target is not supported on rtems so we have chosen i386.
> The bsp is bare and cpu model is pentium. My queries are :
> 1. Is there any method to configure for no-cpu target? When we have
> tried to do that it takes by default host target on which it is running.
> 2. How to segregate target specific stuff from the code ? Any pointer in
> this direction will be highly appreciated.
> regards
> Vinod
