Porting Rtems code( TCP/IP) stack on proprietary RTOs
Sat Jan 5 15:42:09 UTC 2002
Vinod Singh wrote:
> Hi,
> We  have to do Rtems code porting to some proprietary Real Time
> Operating system.
If it is an in-house RTOS, then I encourage you to consider letting
OAR add support for your API to RTEMS itself.  RTEMS is structured
around a SuperCore that makes it possible to support a variety of
tasking APIs.  That is how the Classic/RTEID/pSOS+, POSIX, and
ITRON APIs all co-exist.
In the long-run, this is a better option.  You will get a long
more bang for your buck this way.
> The following options are used for configuration
> rtems-4.5.0 code:
> "../rtems-4.5.0/configure  --target=i386-rtems --prefix=/usr/local
> --enable-cxx --enable-gmake-print-directory --disable-tests
> --disable-posix --enable-networking --enable-bare-cpu-cflags=pentium
> --enable-bare-cpu-model=pentium --enable-rtemsbsp=bare "
> The required target is not supported on rtems so we have chosen i386.
> The bsp is bare and cpu model is pentium. My queries are :
> 1. Is there any method to configure for no-cpu target? When we have
> tried to do that it takes by default host target on which it is running.
> 2. How to segregate target specific stuff from the code ? Any pointer in
> this direction will be highly appreciated.
> regards
> Vinod
