Q about stack alignment on PowerPC.
Sergei Organov osv at javad.ru
Wed Jan 9 08:06:59 UTC 2002
Joel,
I didn't provide the patch as I've fixed this only in the "old exception
processing" code that I'm using myself but which is AFAIK considered
obsolete.
I also have some other improvements such as disabling FP unit for threads that
are not created as floating-point.
I can easily provide the diff between my version and the current snapshot, I
believe. Is it worth doing?
BR,
Sergei.
Joel Sherrill <joel.sherrill at oarcorp.com> writes:
> Till Straumann wrote:
> > Hi.
> > While browsing the mail archive searching something else,
> > I found this message:
> > http://www.oarcorp.com/rtems/maillistArchives/rtems-users/2000/september/msg00114.html
> > where a possible fix is discussed. However, the 12/10/2001 snapshot
> > still contains the unfixed code.
> > Has the fix been considered unnecessary ?
> I think the response I made says it all.  "If this works for you,
> please send back a real patch and let me know."
> I doubt I ever got a real patch for it.  I agree with you that
> it is still a valid concern/buglet.
> > Regards
> > --Till.
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel at OARcorp.com                 On-Line Applications Research
>    Support Available             (256) 722-9985
