Hitachi H8300 RTEMS Port
Glen M Cornell
cornell at gdls.com
Wed Jan 9 14:03:36 UTC 2002
I'm porting RTEMS to the Hitachi H8300 series processor and creating a BSP for
the Lego Mindstorms Robotics Invention System. There is currently another OS
for the RIS, but it appears to be a more simple non-tasking OS.
I have read the RTEMS porting guide and the BSP and Device Driver Development
Guide, and have a few questions about the port. I'm using the bit, bit_gdb, and
bit_rtems scripts for simplicity. RTEMS 4.5.0 is the source base that I'm using
from the OAR ftp site.
I've run into a problem with the configure script in the c/make directory. The
failure is around the point where the configure script is trying to determine
the capabilities of the c compiler (around line 1251 of the c/make/configure):
cat > conftest.$ac_ext << EOF
#line 1253 "configure"
#include "confdefs.h"
main(){return(0);}
EOF
if { (eval echo configure:1258: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && \
test -s conftest${ac_exeext}; then
[snip]
so I manually invoked the linker with the most basic application:
int main(){return(0);}
using the command:
h8300-rtems-coff-gcc simple.c
But the link failed because crt0.o was not found. Does this mean that the
linker didn't build correctly? Is this a question for the gcc team? Or do I
not really need crt0.o?
Thanks,
glenco
