-current gcc patches for m68k
Aaron J. Grier aaron at frye.com
Wed Jan 9 23:34:48 UTC 2002
in a procrastinative state between device driver hacking, I've been
trying to get m68k-rtems target compiled from the -current cvs versions
of gcc and binutils on one of my NetBSD/i386 boxes.  I found the
following (minor) patches necessary to get gcc to compile.
the m68k libstdc++-v3 patch for atomicity.h is untested... I have no
idea if libstdc++-v3 even works with RTEMS (but am curious to try it
out) but have to get it compiling first.  ;)
I've already submitted the lisbtdc++-v3 patch, but haven't done anything
with the config.gcc parts yet.
  Aaron J. Grier  |   Frye Electronics, Tigard, OR   |  aaron at frye.com
     "In a few thousand years people will be scratching their heads
       wondering how on earth the first computer was invented and
          bootstrapped without a prior computer to do it with."
                    --  Chris Malcolm, on comp.arch
Index: gcc/config.gcc
RCS file: /cvs/gcc/egcs/gcc/config.gcc,v
retrieving revision 1.140
diff -u -r1.140 config.gcc
--- config.gcc	2002/01/07 01:30:10	1.140
+++ config.gcc	2002/01/09 23:22:12
@@ -1972,7 +1972,7 @@
 m68k-*-rtemscoff*)
 	tmake_file="m68k/t-m68kbare t-rtems"
-	tm_file=m68k/rtems.h
+	tm_file="m68k/rtems.h m68k/m68k.h"
 	float_format=m68k
 	if test x$enable_threads = xyes; then
 	  thread_file='rtems'
@@ -1980,7 +1980,7 @@
 m68k-*-rtemself*|m68k-*-rtems*)
 	tmake_file="m68k/t-m68kbare t-rtems m68k/t-crtstuff"
-	tm_file=m68k/rtemself.h
+	tm_file="m68k/rtemself.h m68k/m68k.h"
 	float_format=m68k
 	extra_parts="crtbegin.o crtend.o"
Index: gcc/config/m68k/rtemself.h
RCS file: /cvs/gcc/egcs/gcc/config/m68k/rtemself.h,v
retrieving revision 1.5
diff -u -r1.5 rtemself.h
--- rtemself.h	2001/08/04 01:31:35	1.5
+++ rtemself.h	2002/01/09 23:22:21
@@ -30,6 +30,9 @@
 #define CPP_PREDEFINES "-Dmc68000 -Drtems -D__rtems__ -D__ELF__ \
    -Asystem=rtems -Acpu=mc68000 -Acpu=m68k -Amachine=m68k"
+/* set TARGET_DEFAULT to match CPP_PREDEFINES as above, IE plain 68000 */
+#define TARGET_DEFAULT (MASK_BITFIELD)
 /* Generate calls to memcpy, memcmp and memset.  */
 #ifndef TARGET_MEM_FUNCTIONS
 #define TARGET_MEM_FUNCTIONS
Index: libstdc++-v3/config/cpu/m68k/bits/atomicity.h
RCS file: /cvs/gcc/egcs/libstdc++-v3/config/cpu/m68k/bits/atomicity.h,v
retrieving revision 1.2
diff -u -r1.2 atomicity.h
--- atomicity.h	2001/08/15 16:00:45	1.2
+++ atomicity.h	2002/01/09 23:23:32
@@ -1,6 +1,6 @@
-// Low-level functions for atomic operations: m680x0, x >= 2 version -*- C++ -*-
+// Low-level functions for atomic operations: generic M68k version  -*- C++ -*-
-// Copyright (C) 2001 Free Software Foundation, Inc.
+// Copyright (C) 1999, 2000, 2001, 2002 Free Software Foundation, Inc.
 // This file is part of the GNU ISO C++ Library.  This library is free
 // software; you can redistribute it and/or modify it under the
@@ -27,17 +27,51 @@
 // invalidate any other reasons why the executable file might be covered by
 // the GNU General Public License.
+// there are three cases for m68k-variants I (ajg) am aware of that this
+// file needs to take care of:
+// * variants with the "cas" instruction
+//   68020/30/40/60
+// * variants with the "tas" instruction
+//   cpu32, 5400
+// * variants with no atomic read/modify/write instruction at all
+//   68000/10, 5200/300
+// code for cas method was pre-existing, tas method was written by
+// Aaron J. Grier <aaron at frye.com>, and interrupt disable method comes
+// from Eric Norum <eric at cls.usask.ca> and
+// Joel Sherrill <joel.sherrill at oarcorp.com>
 #ifndef _BITS_ATOMICITY_H
 #define _BITS_ATOMICITY_H	1
 typedef int _Atomic_word;
+// atomically increment *__mem by __val and return the old *__mem
-static inline _Atomic_word
+static inline _Atomic_word
 __attribute__ ((__unused__))
 __exchange_and_add (volatile _Atomic_word *__mem, int __val)
   register _Atomic_word __result = *__mem;
+#if defined(__mcpu32__) || defined(__mcf5400__)
+  static char __lock = 0;	// needs to be a byte
+  // tas method
+  __asm__ __volatile__ ( "1: tas %1;"
+		 	 "   jbne 1b;"
+			 "   move%.l %3, %0;"
+			 "   add%.l %2, %3;"
+			 "   clrb %1;"
+			 : "=d" (__result), "=m" (__lock)
+			 : "d" (__val), "m" (*__mem), "0" (__result)
+			 : "memory");
+#else
+#if defined(__mc68020__) || defined(__mc68030__) \
+  || defined(__mc68040__) || defined(__mc68060__)
   register _Atomic_word __temp;
+  // cas method
   __asm__ __volatile__ ("1: move%.l %0,%1;"
 			"   add%.l %2,%1;"
 			"   cas%.l %0,%1,%3;"
@@ -46,16 +80,52 @@
 			: "memory");
   return __result;
+#else
+#if defined(__rtems__) || defined(__vxWorks__) || defined(__embedded__)
+  volatile short __level;
+#if defined(__mcf5200__) || defined(__mcf5300__)
+  // coldfire v2 / v3 interrupt disable
+  unsigned int __tmpsr = 0x700;
+  __asm__ __volatile__ ( "move.w %%sr,%0;"
+			 "or.l   %0,%1;"
+			 "move.w %1,%%sr"
+			 : "=d" (__level), "=d"(__tmpsr)
+			 : "1"(__tmpsr) );
+#else
+  // generic 68000 interrupt disable
+			 "or.w    #0x0700,%%sr"
+	 		 : "=d" (__level) );
+#endif
+#else
+#warning __exchange_and_add is not atomic for current target
+#endif
+  __result = *__mem;
+  *__mem += __val;
+  __asm__ __volatile__ ( "move.w  %0,%%sr " : : "d" (__level) );
+#endif
+#endif
+#endif
+  return __result;
-static inline void
+static void
 __atomic_add (volatile _Atomic_word* __mem, int __val)
-  __asm__ __volatile__ ("add%.l %0,%1"
-			: : "id" (__val), "m" (*__mem) : "memory");
+  static unsigned char __lock;
+  _Atomic_word __tmp;
+  __asm__ __volatile__( "add%.l	%1,(%0)"
+			: "a" (__mem), "d" (__val)
+			: "memory" );
 #endif /* atomicity.h */
