boostrap failing
Jowell, Chris {D177~Roswell} CHRIS.JOWELL at ROCHE.COM
Fri Jan 11 15:49:24 UTC 2002
Hi,
            We have RTEMS 4.5.0 working fine on other workstations but can't
get bootstrap to work on a new PC with SuSE 7.3.  I put part of the error
message below.
I'm sure I've missed something simple but for the life of me I can't figure
out what.
I used the pre-built RTEMS 4.5.0 toolset Linux rpms (Including the m68k
packages) and I've added the location of the toolset and the RTEMS_MAKFILE
to my path
My autoconf is 2.52.44 and automake is 1.4p5-44 if that's interesting.
Christopher Jowell
Application System Analyst
Roche Diagnostics
235 Hembree Park Dr.
Roswell Ga 30076
(770) 576-5000 X 579
(770) 576-5020 Fax
This is part of the error message (If the rest would be helpful please let
me know):
./c/make
configure:1625: error: possibly undefined macro: AC_PROG_CC_G
configure:1758: error: possibly undefined macro: AC_PROG_CXX_WORKS
configure:1766: error: possibly undefined macro: AC_PROG_CXX_G
configure:3032: error: possibly undefined macro: AS_FOR_TARGET
configure:1617: error: possibly undefined macro: AC_PROG_CC_WORKS
configure:1759: error: possibly undefined macro: AC_PROG_CXX_GNU
configure:1618: error: possibly undefined macro: AC_PROG_CC_GNU
./c/src/exec/itron
configure:1575: error: possibly undefined macro: AC_PROG_CC_G
configure:3774: error: possibly undefined macro: AS_FOR_TARGET
configure:1567: error: possibly undefined macro: AC_PROG_CC_WORKS
configure:1568: error: possibly undefined macro: AC_PROG_CC_GNU
./c/src/exec
configure.in:67: warning: AC_CONFIG_SUBDIRS: you should use literals
configure.in:68: warning: AC_CONFIG_SUBDIRS: you should use literals
 <snip>
URL: <http://lists.rtems.org/pipermail/users/attachments/20020111/4c9bb0cc/attachment.html>
