ATM and FreeBSD
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Jan 17 16:36:27 UTC 2002
Does anyone know the real status of ATM for FreeBSD? As best
I can tell it looks like it is there.
http://www.freebsd.org/relnotes/4-STABLE/hardware/i386/x26.html#AEN1200
lists the supported ATM interfaces and protocols which includes these
protocols:
> The ATM support in FreeBSD supports the following signaling protocols:
> The ATM Forum UNI 3.1 signaling protocol
> The ATM Forum UNI 3.0 signaling protocol
> The ATM Forum ILMI address registration
> FORE Systems' proprietary SPANS signaling protocol
> Permanent Virtual Channels (PVCs)
> Support for the IETF ``Classical IP and ARP over ATM'' model is provided, compliant with the following RFCs and
> Internet Drafts:
> RFC 1483, ``Multiprotocol Encapsulation over ATM Adaptation Layer 5''
> RFC 1577, ``Classical IP and ARP over ATM''
> RFC 1626, ``Default IP MTU for use over ATM AAL5''
> RFC 1755, ``ATM Signaling Support for IP over ATM''
> RFC 2225, ``Classical IP and ARP over ATM''
> RFC 2334, ``Server Cache Synchronization Protocol (SCSP)''
> Internet Draft draft-ietf-ion-scsp-atmarp-00.txt, ``A Distributed ATMARP Service Using SCSP''
I still wonder if the best way to get this support in RTEMS is to
port a new version of the BSD stack.
joel at OARcorp.com On-Line Applications Research
