Help for use the bit script under cygwin!
dei dei
leo_dvdv at yahoo.com.cn
Fri Jan 18 01:51:09 UTC 2002
Hello all,
I have a problem building RTEMS toolchain under
the Cygwin-2.125.2.10 environment on Win NT. The
operations are as follows...
1) I have modified the path adding:
PATH=/usr/local/rtems/bin:$PATH
2) make a little trick to get this compilation:
ln gcc.exe cc.exe in/bin (in /bin)
ln make.exe gmake.exe in/bin (in /bin)
cd gcc-2.95.2 (in tools directory)
ln -s ../newlib-1.8.2/newlib .
3) in order to compile without problems and another
last trick: change with regedit.exe
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\WOW\cmdline
from
'%SystemRoot%\system32\ntvdm.exe' to
'%systemRoot%\system32\ntvdm.exeXXX'
to disable the execution of msdos 16 bits programs.
4) execute the follow instruction
./bit i386 >bit.log 2>&1 &
The info of errors are in file of bit.log, by the
way,I have followed the instructions in the
Getting Started guide.
Thanks for any help!
David
-----The partiall content of bit.log is following ----
GNU makeinfo 1.68 or newer is required to build some
of the documentation included with this package. You
have version makeinfo (GNU texinfo) 4.0
Building a cross GNU C/C++ toolset with the following
configuration:
BINUTILS --> binutils-2.9.5.0.24
GCC --> gcc-2.95.2
NEWLIB --> newlib-1.8.2
TARGET --> i386-rtems
INSTALL POINT --> /usr/local/rtems
BUILD DOCS --> yes
Making directory for install point (/usr/local/rtems)
Compilation of binutils will occur in
build-i386-tools.
BIT: Running in
/home/Administrator/tools/build-i386-tools:
+ ../binutils-2.9.5.0.24/configure --target=i386-rtems
--verbose --prefix=/usr/local/rtems
Configuring for a i686-pc-cygwin32 host.
BIT: Running in
+ gmake all info install
gmake[1]: Entering directory
`/home/Administrator/tools/build-i386-tools/libiberty'
gcc -c -DHAVE_CONFIG_H -g -O2 -W -Wall -I.
-I../../binutils-2.9.5.0.24/libiberty/../include
../../binutils-2.9.5.0.24/libiberty/strerror.c
../../binutils-2.9.5.0.24/libiberty/strerror.c:461:
conflicting types for `sys_errlist'
/usr/include/sys/errno.h:23: previous declaration of
`sys_errlist'
gmake[1]: *** [strerror.o] Error 1
gmake[1]: Leaving directory
gmake: *** [all-libiberty] Error 2
ERROR: **** FAILED **** unable to build binutils
Started: Thu Jan 17 08:55:48 2002
Finished: Thu Jan 17 09:00:21 2002
Directory size information:
1739 build-i386-tools
0 /usr/local/rtems
The src and build-i386-tools subdirectory have NOT
been removed.
_________________________________________________________
Do You Yahoo!? 登录免费雅虎电邮! http://mail.yahoo.com.cn
<font color=#6666FF>无聊?郁闷?高兴?没理由?都来聊天吧!</font>――
雅虎全新聊天室! http://cn.chat.yahoo.com/c/roomlist.html
