librdbg fix for PowerPC
Till Straumann
strauman at SLAC.Stanford.EDU
Fri Jan 18 05:36:11 UTC 2002
Hi.
Today was RDBG day for me. I started using the debugger
for EPICS applications on PowerPC / SVGM5.
However, librdbg needed to be fixed - the out of the box
version didn't work (see comments in the patch file)
-- Till.
RTEMS librdbg patch (against rtems-ss-20011210)
Author: Till Straumann <strauman at slac.stanford.edu>
This patch addresses the following issues:
- exception handler needs to enable MSR_FP if the
interrupted thread is FP enabled.
- printk message for MSR fixed and
added stacktrace
NOTE: this requires the stacktrace
patch to lib/libbsp/powerpc/shared/vectors/vector_init.c
(#ifdef DDEBUG only, however)
Index: c/src/librdbg//src/powerpc/excep_f.c
RCS file: /afs/slac/g/spear/cvsrep/rtems/src/c/src/librdbg/src/powerpc/excep_f.c,v
retrieving revision 1.1.1.1
retrieving revision 1.2
diff -c -r1.1.1.1 -r1.2
*** c/src/librdbg//src/powerpc/excep_f.c 2001/12/14 22:54:21 1.1.1.1
--- c/src/librdbg//src/powerpc/excep_f.c 2002/01/18 05:25:44 1.2
*** 56,61 ****
--- 56,73 ----
rtems_status_code status;
rtems_id continueSemId;
+ /* T. Straumann, 1/16/2002: we must re-enable the floating point engine
+ * if the interrupted thread is FP. Otherwise,
+ * the semaphore primitives may crash when they
+ * try to save FP context while switching this
+ * thread...
+ if (ctx->EXC_SRR1 & 0x2000) {
+ register unsigned long msr;
+ __asm__ __volatile__("mfmsr %0":"=r"(msr));
+ __asm__ __volatile__("mtmsr %0"::"r"(msr|MSR_FP));
if ( (justSaveContext) && (ctx->_EXC_number == ASM_SYS_VECTOR) ) {
PushSavedExceptCtx (_Thread_Executing->Object.id, ctx);
justSaveContext = 0;
*** 114,120 ****
printk("\t CTR = %x\n", ctx->EXC_CTR);
printk("\t XER = %x\n", ctx->EXC_XER);
printk("\t LR = %x\n", ctx->EXC_LR);
! printk("\t MSR = %x\n", ctx->EXC_MSR);
#endif
status = rtems_semaphore_create (rtems_build_name('D', 'B', 'G', 'c'),
--- 126,132 ----
! printk("\t MSR = %x\n", ctx->EXC_SRR1);
#endif
*** 151,156 ****
--- 163,173 ----
default:
DPRINTF((" OTHER EXCEPTION !!!\n"));
+ #ifdef DDEBUG
+ { extern void BSP_printStackTrace();
+ BSP_printStackTrace(ctx);
+ #endif
rtems_semaphore_release( wakeupEventSemId );
break;
