RTEMS pty driver
Fernando RUIZ CASAS (E-mail) fernando.ruiz at ctv.es
Fri Jan 18 10:54:28 UTC 2002
Sorry for the delay but I'am working out of my office.
printk is the trick to print error messages in the kernel routines.
#define printk printf is a very bad solution.
But I don't known all the BSP structure.
Cerntainly printf is not safe at this moment.
In the PC386 and calling before to /dev/console initialization in the other
BSPS
could be more safe.
Solution. REMOVE IT.
You don't need the maximum pty devices in the start.
Only a useful information when you have any problem.
A serial device driver adaption from the PC386.
Sorry for the inconvenience.
Joel, Please . Can you remove it for me?
I don't have any platform at this moment availiable to compile rtems. Sorry.
I'm very happy known that anybody uses my poor contribution to RTEMS.
-----Mensaje original-----
De: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
Enviado el: jueves, 17 de enero de 2002 14:16
Para: Ralf Corsepius
CC: Till Straumann; Fernando RUIZ CASAS; RTEMS Users
Asunto: Re: RTEMS pty driver
Ralf Corsepius wrote:
> Am Mit, 2002-01-16 um 04.16 schrieb Till Straumann:
> > Fernando.
> > I had a problem with my application because
> > the stdout stream had its error flag (__SERR)
> > set on entry to my Initialization task.
> > I tracked it down and found that your pty
> > driver (src/libnetworking/rtems_telnetd/pty.c)
> > redefines
> > ( $Id: pty.c,v 1.1 2001/08/09 22:06:51 joel Exp $ )
> This doesn't look right, IHMO.
> > However, pty_initialize() (which calls printk) ends
> > up calling printf() at driver initialization time when it
> > is not yet safe to use stdio (at least on some BSPs).
> > Shouldn't the driver use the true printk() ?
> If pty_initialize is called at driver initialization time, as you say,
> then using printf there is not correct.
Ralf's correct.  It is not safe to use printf at all before the
tasking is running.
We had to move C++ constructors to execute after tasking was initiated
for this very reason.
> May-be Fernando should comment on this. What was the rationale to use
> printf there?
> Ralf
