Help for use the bit script under cygwin!
Fri Jan 18 14:05:58 UTC 2002
I highly recommend avoiding the bit scripts and just
running configure and make.
The bit script is officially deprecated and will
probably not be included in the next majos release.
--joel
Puro Markku wrote:
> Hi All,
> I run into similar problems with newer cygwin1.dll(cygwin-1.3.4 ...
> cygwin-1.3.6)
> Cygwin-tool versions that I'm using are:
>  autoconf autoconf-2.13-2.tar.gz
>  automake automake-1.4-4.tar.gz
>  cygwin   cygwin-1.3.2-1.tar.gz
>  binutils binutils-20011002-1.tar.bz2
>  gcc        gcc-2.95.3-5.tar.bz2
>  make     make-3.79.1-4.tar.bz2
> (at least those seems to work whithout any 'major' problems)
> Markku Puro           markku.puro at insta.fi          Sarankulmankatu 20
>                       tel.   +358 3  2659 769       FIN-33900 Tampere
> INSTRUMENTOINTI OY    mobile +358 40 7092 769       http://www.insta.fi
> C3i Systems           fax    +358 3  2659 501
> > -----Original Message-----
> > From: dei dei [mailto:leo_dvdv at yahoo.com.cn]
> > Sent: 18. tammikuuta 2002 3:51
> > To: rtems-users at OARcorp.com
> > Subject: Help for use the bit script under cygwin!
> > Hello all,
> >     I have a problem building RTEMS toolchain under
> > the Cygwin-2.125.2.10 environment on Win NT. The
> > operations are as follows...
> >    1) I have modified the path adding:
> >        PATH=/usr/local/rtems/bin:$PATH
> >    2) make a little trick to get this compilation:
> >        ln gcc.exe cc.exe in/bin       (in /bin)
> >        ln make.exe gmake.exe in/bin   (in /bin)
> >        cd gcc-2.95.2  (in tools directory)
> >        ln -s ../newlib-1.8.2/newlib .
> >    3) in order to compile without problems and another
> > last trick: change with  regedit.exe
> > HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\WOW\cmdline
> > from
> >     '%SystemRoot%\system32\ntvdm.exe' to
> >     '%systemRoot%\system32\ntvdm.exeXXX'
> > to disable the execution of msdos 16 bits programs.
> >    4) execute the follow instruction
> >     ./bit i386 >bit.log 2>&1 &
> > The info of errors are in file of bit.log, by the
> > way,I have followed the instructions in the
> > Getting Started guide.
> > Thanks for any help!
> > David
> > -----The partiall content of bit.log is following ----
> > GNU makeinfo 1.68 or newer is required to build some
> > of the documentation included with this package.  You
> > have version makeinfo (GNU texinfo) 4.0
> > Building a cross GNU C/C++ toolset with the following
> > configuration:
> >     BINUTILS      -->  binutils-2.9.5.0.24
> >     GCC           -->  gcc-2.95.2
> >     NEWLIB        -->  newlib-1.8.2
> >     TARGET        -->  i386-rtems
> >     INSTALL POINT -->  /usr/local/rtems
> >     BUILD DOCS    -->  yes
> > Making directory for install point (/usr/local/rtems)
> > Compilation of binutils will occur in
> > build-i386-tools.
> > BIT: Running in
> > /home/Administrator/tools/build-i386-tools:
> > + ../binutils-2.9.5.0.24/configure --target=i386-rtems
> > --verbose --prefix=/usr/local/rtems
> > Configuring for a i686-pc-cygwin32 host.
> > BIT: Running in
> > + gmake all info install
> > gmake[1]: Entering directory
> > `/home/Administrator/tools/build-i386-tools/libiberty'
> > gcc -c -DHAVE_CONFIG_H -g -O2 -W -Wall -I.
> > -I../../binutils-2.9.5.0.24/libiberty/../include
> > ../../binutils-2.9.5.0.24/libiberty/strerror.c
> > ../../binutils-2.9.5.0.24/libiberty/strerror.c:461:
> > conflicting types for `sys_errlist'
> > /usr/include/sys/errno.h:23: previous declaration of
> > `sys_errlist'
> > gmake[1]: *** [strerror.o] Error 1
> > gmake[1]: Leaving directory
> > gmake: *** [all-libiberty] Error 2
> > ERROR: **** FAILED **** unable to build binutils
> > Started:   Thu Jan 17 08:55:48 2002
> > Finished:  Thu Jan 17 09:00:21 2002
> > Directory size information:
> > 1739  build-i386-tools
> > 0     /usr/local/rtems
> > The src and build-i386-tools subdirectory have NOT
> > been removed.
> > _________________________________________________________
> > Do You Yahoo!? µÇ¼Ãâ·ÑÑÅ»¢µçÓÊ! http://mail.yahoo.com.cn
> > <font color=#6666FF>ÎÞÁÄ£¿ÓôÃÆ£¿¸ßÐË£¿Ã»ÀíÓÉ£¿¶¼À´ÁÄÌì°É£¡</font>¡ª¡ª
> > ÑÅ»¢È«ÐÂÁÄÌìÊÒ! http://cn.chat.yahoo.com/c/roomlist.html
