autoconf help
Glen Cornell
glen at metrolink.com
Fri Jan 18 18:28:09 UTC 2002
I'm trying to incorporate the xfree86 loader into the rtems tree at the
c/src/libmisc/loader
I've managed to create a Makefile.ac that uses conditionals to support the
target object file formats such as in the example below:
if elf_loader
# Using the elf loader:
ELF_SRCS = elfloader.c
ELF_FLAGS = -DELF_SUPPORT
endif
My question is that how do I set up the conditional in my configure.in script?
How do I know what object file formats are supported by the cross compiler? I
thought that this might be a starting point:
AM_CONDITIONAL(elf_loader, i386-rtems-objdump --info | grep elf)
Is there an easier/better way?
One last question, how do I specify the proper cross objdump to use?
TIA,
glenco
