MSR storing - to Joel and E.Valette
leonp leonp at plris.com
Thu Jan 24 09:29:42 UTC 2002
Hello,
	Some points are still not clear for me:
Joel:
>This is the way RTEMS was spec'ed, designed, and implemented. :)
>Interrupt level is maintained per task (see rtems_task_mode()).
Yes, this is correct IMHO. But in MPC860 MSR doesn't contain the interrupt
level, but the global interrupt enable bit only.
>Interrupt disable level and FPU enable are maintained on a per task
>basis.
The MPC860 cpu does not have FPU. I suppose that you mean the FP context, yes?
Eric Valette:
>Yes this will in general : the MSR status is a thread attribute that
>shall not be lost. It contains for example the FP status (enabled
>disabled, single stepping) that you cannot lost when switching back.
OK, now, if I want the CPU to be in single stepping, I personally definitely
don't want to switch the contexts. The FP enabling is illegal for MPC860.
In general -  IMHO, the MSR is the MACHINE state register. I looked through
all it bits once more and didn't find one that seems to be thread relative.
Thanks.
leonp at plris.com
