termios with outputUsesInterrupts=TERMIOS_TASK_DRIVEN
Mike Siers mikes at poliac.com
Thu Jan 31 14:29:47 UTC 2002
Hi Stan,
I believe the TERMIOS_TASK_DRIVEN mode was added to support
the pppd application.  Currently, if you want to use pppd then
your BSP console driver must be updated to support this
TASK_DRIVEN mode.  If you do not plan on using pppd, then this
mode is not needed.
As a side note, I have made a new port of the pppd application
that does not require the use of TERMIOS_TASK_DRIVEN mode.  This
version of pppd should work with any BSP and also fixes the
large packet problem of the current version.  I will be posting
this version back to the RTEMS source tree.  If anyone is
interested in helping test it, please contact me.
Mike Siers
-----Original Message-----
Sent: Wednesday, January 30, 2002 10:53 AM
To: rtems-users at oarcorp.com
Subject: termios with outputUsesInterrupts=TERMIOS_TASK_DRIVEN
Hi,
Does anyone use termios with TERMIOS_TASK_DRIVEN mode ?
Most BSP use TERMIOS_POLLED  or  TERMIOS_IRQ_DRIVEN;
I am looking for an example source of console.c with that.
Thanks a lot.
        Stan .
Note: my BSP running properly with outputUsesInterrupts = 0, but not with
outputUsesInterrupts 2.
