Support for multiple ethernet ports
Thomas Doerfler Thomas.Doerfler at imd-systems.de
Wed Jan 2 21:35:46 UTC 2002
Hi,
since nobody answered up to now, I will try to add my 2 cents
of knowledge here...
> It appears from reading the RTEMS network supplement that RTEMS can
> supports multiple Ethernet ports.  For my application, I would like to
> configure RTEMS to support 3 Ethernet ports.
I have an application running with one ethernet port
(MC68360), one local loopback interface, and one PPP
interface, so from the protocol stack point of view this must
be quite similar. RTEMS should definitely support multiple
networking interfaces.
The only difference to your application is, that you have a
different device and possibly multiple devices of the same
type. How do you distinguish the network interfaces on driver
level? Maybe some part of the software doesn't work properly
with an identical major number or so?
> I have successfully configured RTEMS to use a single Ethernet port.  When
> I configure RTEMS to use two ports, part way through the initialization of
> the second port I get the following error:
>     Can't set eth2 address: File exists
> This error message is in rtems_glue.c at approximately line 828.  The call
> to ioctl (s, SIOCSIFADDR, &ifreq) returns with a failure.
> Since RTEMS seems to support multiple Ethernet port, I am assuming that I
> have not correctly configured the building of RTEMS.  How do I configure
> RTEMS to support 3 Ethernet ports?
I don't think this is a building problem, possibly you should
look for a problem in the code involved. I had a look into the
"gen68360" networking driver, it does not distinguish between
multiple devices, although the hardware would be capable to
supply multiple ethernet interface. The same is true for the
entries in the "netdriver_config" table. So have you created
your own mechanism to distinguish multiple devices on
driver/configuration level? Maybe you got a problem there?
Bye,
	Thomas.
> TIA
> Alex
> Alex Holeczy (alex at wmi.com)
> Communication Automation Corporation (CAC)      www.cacdsp.com www.wmi.com
> 1180 McDermott Drive, West Chester, PA  19380
> 800-367-6735 Ext. 122 or 610-692-9526 Ext. 122 (Voice)
> 610-436-8258 (Fax)
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler           Herbststrasse 8
D-82178 Puchheim          Germany
email:    Thomas.Doerfler at imd-systems.de
PGP public key available at: http://www.imd-
systems.de/pgp_key.htm
