rtems exception handling
Thu Jan 10 20:51:42 UTC 2002
> "Hennenfent, Nick {AVL~Roswell}" wrote:
> I have tried using
> try
>     // do something that throws an exception
> catch (...)
>     // report an error
> blocks but when an exception is thrown, I end up getting an
> rtems_fatal_error because the stack checker thinks the stack
> is corrupt.
> Does anyone know if this is even supposed to work???
> Are exceptions incompatible with the rtems stack checker???
They shouldn't be.  The stack checker is very simple and
probably really flagging a blown stack.  It writes a known pattern
into the stack and checks to see if the last N bytes of the
stack always have that pattern.  If they don't, you
have blown the stack.  Stack checking is only done
during a context switch so more than likely the exception
is just the first time you are switching since the actually
point of blowing up.
> Thanks.
> Nick
