problems with latest snapshot
Peter Mueller
peter.o.mueller at gmx.de
Tue Jul 2 20:10:06 UTC 2002
Hi all,
I have problems to build the latest snapshop of rtems. Everthing works fine till the hello example in tests should be linked. The linker did not find rtemsall. And really, the lib was not built.
Any idea what went wrong?
Thanks,
Peter
Error Msg:
m68k-rtems-gcc --pipe -B../../../../../lib/ -B../../../../../efi332/lib/ -specs bsp_specs -qrtems -g -Wall -mcpu32 -ansi -fasm -L ../../../../../efi332/lib -O4 -fomit-frame-pointer -o o-optimize/hello.nxe o-optimize/init.o ../../../../../efi332/lib/no-dpmem.rel ../../../../../efi332/lib/no-event.rel ../../../../../efi332/lib/no-msg.rel ../../../../../efi332/lib/no-mp.rel ../../../../../efi332/lib/no-part.rel ../../../../../efi332/lib/no-signal.rel ../../../../../efi332/lib/no-timer.rel ../../../../../efi332/lib/no-rtmon.rel
/opt/rtems/m68k-rtems/bin/ld: cannot find -lrtemsall
collect2: ld returned 1 exit status
gmake[5]: *** [o-optimize/hello.exe] Fehler 1
System Info:
m68k-rtems-gcc --version
2.95.3
m68k-rtems-ld --version
GNU ld 2.10
Copyright 2000 Free Software Foundation, Inc.
This program is free software; you may redistribute it under the terms of
the GNU General Public License. This program has absolutely no warranty.
Supported emulations:
m68kelf
autoconf --version
autoconf (GNU Autoconf) 2.52
automake --version
automake (GNU automake) 1.6.2
"This is an object-oriented system.
If we change anything, the users object."
Name: not available
Type: application/pgp-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20020702/73b3da77/attachment.bin>
