problems with latest snapshot
Peter Mueller
peter.o.mueller at gmx.de
Wed Jul 3 21:11:57 UTC 2002
Hi Ralf,
thanks for the tip. I really use a custom efi332 BSP with the snapshot from 20010326. Changing the bsp_spec file as you proposed solved the problem.
Thanks again,
Peter
On 03 Jul 2002 20:12:21 +0200
Ralf Corsepius <corsepiu at faw.uni-ulm.de> wrote:
> Am Mit, 2002-07-03 um 19.34 schrieb Peter Mueller:
> > Hi all,
> > I have problems to build the latest snapshop of rtems. Everthing works fine till the hello example in tests should be linked. The linker did not find rtemsall. And really, the lib was not built.
> > Any idea what went wrong?
> Yes, librtemsall.has been replaced by two new libraries:
> librtemsbsp.a and librtemscpu.a.
> > Thanks,
> > Peter
> > Error Msg:
> > m68k-rtems-gcc --pipe -B../../../../../lib/ -B../../../../../efi332/lib/ -specs bsp_specs -qrtems -g -Wall -mcpu32 -ansi -fasm -L ../../../../../efi332/lib -O4 -fomit-frame-pointer -o o-optimize/hello.nxe o-optimize/init.o ../../../../../efi332/lib/no-dpmem.rel ../../../../../efi332/lib/no-event.rel ../../../../../efi332/lib/no-msg.rel ../../../../../efi332/lib/no-mp.rel ../../../../../efi332/lib/no-part.rel ../../../../../efi332/lib/no-signal.rel ../../../../../efi332/lib/no-timer.rel ../../../../../efi332/lib/no-rtmon.rel
> > /opt/rtems/m68k-rtems/bin/ld: cannot find -lrtemsall
> > collect2: ld returned 1 exit status
> > gmake[5]: *** [o-optimize/hello.exe] Fehler 1
> Is this with the efi332 BSPs from the snapshot or is this a customized
> BSP? If the former, this would mean a bug in the snapshot, if with a
> customized BSP you probably need to change your bsp_specs's *lib rule
> into something similar to this:
> *lib:
> %{!qrtems: %(old_lib)} %{qrtems: --start-group \
> %{!qrtems_debug: -lrtemsbsp -lrtemscpu} \
> %{qrtems_debug: -lrtemsbsp_g -lrtemscpu_g} \
> -lc -lgcc --end-group \
> %{!qnolinkcmds: -T linkcmds%s}}
> Ralf
"This is an object-oriented system.
If we change anything, the users object."
Name: not available
Type: application/pgp-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20020703/32649b15/attachment.bin>
