bdm error
Chris Johns cjohns at cybertec.com.au
Mon Jul 15 02:09:25 UTC 2002
Aaron J. Grier wrote:
> On Fri, Jul 12, 2002 at 02:49:53PM -0400, D. Peter Siddons wrote:
>>OK, so my gdb problem was due to the fact that I compiled the code
>>using gcc-3.1 instead of gcc-2.95, and was debugging with gdb-5.0. If I
>>open the file with gdb-5.2 then there are no complaints. Is there a bdm
>>patch for gdb-5.2?
> I started with the cybertec gdb 5.0 patch, and hand-applied the
> rejects.  seems to work.  give me a couple days and I could probably get
> a patch together, although I imagine it'd be easier for Chris Johns to
> do that.  ;)
Given the time which I have had little of to put to this task. A patch is most welcome :-)
  Chris Johns, cjohns at cybertec.com.au
