Problem with default gateway
Vyacheslav V. Burdjanadze wr at zelax.ru
Fri Jul 19 18:34:56 UTC 2002
Ilya Alexeev suggest to patch rtrequest (for those interested) to solve
problem. He tested it, I tested it too on two Motorola PPC 860 boards.
This is patched fragment of rtrequest function..
         case RTM_ADD:
                 if ((flags & RTF_GATEWAY) && !gateway)
                         panic("rtrequest: GATEWAY but no gateway");
                 if ((ifa = ifa_ifwithroute(flags, dst, gateway)) == 0)
                         struct rtentry *rt1 = rtalloc1(gateway,0,0UL);
                         if (rt1) {
                             ifa = rt1->rt_ifa;
                             RTFREE(rt1);
                             if (!ifa)
                                 senderr(ENETUNREACH);
                         else
         makeroute:
Assume you have two boards connected directly by their interfaces with
addresses 192.168.10.1/24 and 192.168.11.1/24. You should add route to
remote network by issuing rtrequest, and then add gateway that resides
in remote (non local) network as Ilya suggest in his posts above.
- " Why do you call this software 'beta' ? "
- " Cuz it beta than nothin' ! "
