Remote debugging
Eric Norum eric.norum at usask.ca
Fri Jul 26 20:29:32 UTC 2002
Where's the documentation on setting up remote debugging for an
i386-rtems/pc386 target?
   (note to Joel -- It's a real pain that the Search button on the OAR
web server still doesn't work!)
I've downloaded the source and patches from the OAR snapshot page:
gdb-5.2-rtems-base-20020612.diff
gdb-5.2-rtems-cg-20020612.diff
gdb-5.2-rtems-rdbg-20020612.diff
gdb-5.2.tar.gz
I've applied the patches but when I try to configure I get
% ../gdb-5.2/configure --target=i386-RTEMS
../gdb-5.2/configure: read-only variable: PWD [152]
Configuring for a powerpc-apple-darwin5.5 host.
Invalid configuration `i386-RTEMS': system `RTEMS' not recognized
Unrecognized target system name i386-RTEMS.
If I configure with --target=i386-rtems I can build gdb, but it doesn't
build the RPC/XDR routines for remote debugging.
Eric Norum <eric.norum at usask.ca>
Department of Electrical Engineering
University of Saskatchewan
Saskatoon, Canada.
Phone: (306) 966-5394   FAX:   (306) 966-5407
Name: not available
Type: text/enriched
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20020726/4d6e42c0/attachment.bin>
