Spam mailers
Leon Pollak
leonp at plris.com
Mon Jul 29 07:48:34 UTC 2002
Hello, All.
During the last several months I started to receive 5-7 spam e-mails
containing viruses.
According to the names of "sending" people in "From" part, I understand, that
the spamer is subscribed to our list and sucks the addresses and names from
it.
Is it possible to hide sender's name in RTEMS lists?
P.S. Among the "From:" senders are: Quality Quorum, Eric Vallete and some
others.
leonp at plris dot com
Return-Path: <jeff.mayes at OARcorp.com>
Mailing-List: contact rtems-users-help at oarcorp.com; run by ezmlm
Delivered-To: mailing list rtems-users at oarcorp.com
Received: (qmail 3928 invoked from network); 29 Jul 2002 14:57:15 -0000
Received: from unknown (HELO OARcorp.com) (192.168.1.19)
by 0 with SMTP; 29 Jul 2002 14:57:15 -0000
Message-ID: <3D4558C8.F11C8E55 at OARcorp.com>
Date: Mon, 29 Jul 2002 10:01:28 -0500
X-Mailer: Mozilla 4.79 [en] (Windows NT 5.0; U)
X-Accept-Language: en
MIME-Version: 1.0
To: leonp at plris.com
CC: RTEMS List <rtems-users at oarcorp.com>
Subject: Re: Spam mailers
References: <200207291048.34077.leonp at plris.com>
Content-Type: text/plain; charset=us-ascii
Content-Transfer-Encoding: 7bit
OK. I've removed the "From" header information from future postings,
which will remove the senders email address from the message when it is
sent out to the list. This can be changed back if it negatively affects too
many of you.
I've seen lots of header forgeries lately from spammers. They can
use just about anything for a From header. I don't think they are
subscribed to the list, but could be getting the email addresses off
the message archive web pages. :(
Jeff
Leon Pollak wrote:
> Hello, All.
> containing viruses.
> it.
> others.
Return-Path: <jerry.needell at unh.edu>
Received: (qmail 6617 invoked from network); 29 Jul 2002 16:22:19 -0000
Received: from unknown (HELO tweedledee.sr.unh.edu) (132.177.247.110)
by 0 with SMTP; 29 Jul 2002 16:22:19 -0000
Received: from unh.edu (browndog.sr.unh.edu [132.177.247.129])
by tweedledee.sr.unh.edu (8.11.6/linuxconf) with ESMTP id g6TGMIE15832;
Mon, 29 Jul 2002 12:22:18 -0400
Message-ID: <3D456BEF.5000907 at unh.edu>
Date: Mon, 29 Jul 2002 12:23:11 -0400
User-Agent: Mozilla/5.0 (X11; U; Linux i686; en-US; rv:1.0.0) Gecko/20020529
X-Accept-Language: en-us, en
MIME-Version: 1.0
To: Jerry Needell <jerry.needell at unh.edu>
CC: rtems-users at oarcorp.com
Subject: Re: gdb 5.0 build problem
References: <3D4435F2.8080807 at unh.edu>
Content-Type: text/plain; charset=us-ascii; format=flowed
Jerry Needell wrote:
> I was re-creating rtems 4.5.1pre3 on a new system and followed the
> "Getting Started" manual for building the c-tools.
> When trying to build gdb-5.0 on my Redhat 7.3 Linux box, the build
> failed with the atteached error. Has anyone seen this. Have I forgotten
> something or is this some new conflict with the Redhat 2.96
> installation. There have been recent updates to the Redhat system.
> My configure was simply
> ../gdb-5.0/configure --target=sparc-rtems --prefix=/opt/rtems --enable-sim
> the gdb-5.0-rtems-20010314.diff patch was applied.
> binutils 2.10 and gcc 2.95.3 built without any problems.
> Any suggestions would be appreciated - Jerry
> gcc -c -g -O2 -I. -I../../gdb-5.0/gdb -I../../gdb-5.0/gdb/config -DHAVE_CONFIG_H -I../../gdb-5.0/gdb/../include/opcode -I../../gdb-5.0/gdb/../readline/.. -I../bfd -I../../gdb-5.0/gdb/../bfd -I../../gdb-5.0/gdb/../include -I../intl -I../../gdb-5.0/gdb/../intl -I../../gdb-5.0/gdb/tui -DUSE_INCLUDED_REGEX ../../gdb-5.0/gdb/utils.c
> In file included from /usr/include/curses.h:111,
> from ../../gdb-5.0/gdb/utils.c:28:
> /usr/lib/gcc-lib/i386-redhat-linux/2.96/include/stdbool.h:39: conflicting types for `false'
> ../bfd/bfd.h:101: previous declaration of `false'
> /usr/lib/gcc-lib/i386-redhat-linux/2.96/include/stdbool.h:41: conflicting types for `true'
> ../bfd/bfd.h:101: previous declaration of `true'
> make[1]: *** [utils.o] Error 1
> make[1]: Leaving directory `/home/needell/rtems/tools/b-gdb/gdb'
> make: *** [all-gdb] Error 2
I should have doen my homework before posting this here. It appears this
is a well known problem with gdb and 2.96. There are some suggeste
workarounds out there, but they are pretty messy. I tried upgrading my
system to use gcc 3.1 and everything compiled fine and even seems to
work! Has anyone had any experience with 3.1 and are there any known
issues with using it to compile the tools?
- Jerry
Jerry Needell -- UNH Space Science Center
telephone: (603) 862 2732 - fax: (603)862 0311
e-mail: jerry.needell at unh.edu
