problems with latest snapshot
Ralf Corsepius corsepiu at faw.uni-ulm.de
Wed Jul 3 19:08:08 UTC 2002
Am Mit, 2002-07-03 um 20.20 schrieb Eric Norum:
> On Wednesday, July 3, 2002, at 12:12 PM, Ralf Corsepius wrote:
> > Am Mit, 2002-07-03 um 19.34 schrieb Peter Mueller:
> >> Hi all,
> >> I have problems to build the latest snapshop of rtems. Everthing works
> >> fine till the hello example in tests should be linked. The linker did
> >> not find rtemsall. And really, the lib was not built.
> >> Any idea what went wrong?
> > Yes, librtemsall.has been replaced by two new libraries:
> > librtemsbsp.a and librtemscpu.a.
> Hmm..
> I can't even get that far:
This probably is different issue, but I am not sure about it.
> i386-rtems-gcc --pipe -B../../../.././lib/ -B../../../.././pc386/lib/
> -specs bsp_specs -qrtems -DHAVE_CONFIG_H  -Isrc  -ansi -fasm      -O4
> -g -Wall   -o o-optimize/newlibc.o -c
> ../../../../../../rtems-ss-20020628/c/src/exec/libcsupport/src/newlibc.c
> ss-20020628/c/src/exec/libcsupport/src/newlibc.c: In function
> `libc_create_hook':
> ss-20020628/c/src/exec/libcsupport/src/newlibc.c:105: structure has no
> member named `libc_reent'
> `libc_start_hook':
> ss-20020628/c/src/exec/libcsupport/src/newlibc.c:147: structure has no
Did you interrupt configuration and rerun configure?
Try running
make RTEMS_BSP=pc386 preinstall
or try starting with a fresh build-tree.
Ralf
