network initialization hangs
Bill Butler billb at tnex.com
Tue Jul 16 14:25:43 UTC 2002
Sachine,
Hi there and I have been where you are -- a lot less hair on my head now
You need to have a card that you have a driver for -- either by writing
it or using one that was already writen. Im not sure if the realTek card
you have is a ne2000 card compatible or not. If not I think there might
be a RealTek driver around but it would most likely be easier to find a
card that has a chip in which there is a driver.  You might try
searching the mail archive on the website for a RealTek driver.
I use some old NE2000 ISA cards to run the i386 code. Works great. But
you will also need to find a dos setup program for your network card so
that you can set the IO Hardware address (0x300,0x330,..) and the irq
(1,3,5).. or at least find out what it is.  The ne2000 driver allows you
to pass in the IO address and IRQ when you initialize it (see
networkconfig.h in netdemo and driver code). In my case for the ne2000
card you need to add to the structure as shown below
Good luck
--- code snip --
 * Default network interface
static struct rtems_bsdnet_ifconfig netdriver_config = {
   RTEMS_BSP_NETWORK_DRIVER_NAME,      /* name */
   RTEMS_BSP_NETWORK_DRIVER_ATTACH, /* attach function */
#ifdef RTEMS_USE_LOOPBACK
   &loopback_config,    /* link to next interface */
#else
   NULL,          /* No more interfaces */
#endif
#if (defined (RTEMS_USE_BOOTP))
   NULL,          /* BOOTP supplies IP address */
   NULL,          /* BOOTP supplies IP net mask */
#else
   "192.168.1.49",      /* IP address */
   "255.255.255.0",     /* IP net mask */
#endif /* !RTEMS_USE_BOOTP */
#if (defined (RTEMS_SET_ETHERNET_ADDRESS))
   ethernet_address,         /* Ethernet hardware address */ <---IO Add
Here
#else
   NULL,                           /* Driver supplies hardware address
#endif
   0,           /* ignore_broadcast */
   0,           /* mtu */
   0,           /* rbuf_count */
   0,           /* xbuf_count*/
   0,           /* port */
   3,           /* irno */
<----- IRQ Here
   0,           /* bpar*/
Bill Butler
Project Lead
Sr Software Engineer
AIPCOM Inc
(972) 644-2328 (x16)
> -----Original Message-----
> From: Sachin K [mailto:sachin at dexceldesigns.com]
> Sent: Tuesday, July 16, 2002 2:03 AM
> To: rtems-users at oarcorp.com
> Subject: network initialization hangs
> Hi,
> from past 3 days i'm experimenting with network driver and bsp
settings.
> i have installed pc386 BSP on RedHat Linux 7.2
> i'm trying to execute ntpdemo provided in netdemos-4.5.0 .
> when i boot with ntpdemo.exe my pc hangs at
> "rtems_bsdnet_initialize_network ();" routine .
> i have tried the following bsp.h settings.
> #define BSP_3C509_NETWORK_DRIVER_NAME		"ep0"
> #define BSP_3C509_NETWORK_DRIVER_ATTACH
rtems_3c509_driver_attach
> result : fail to find board
> #if 0
> #define RTEMS_BSP_NETWORK_DRIVER_NAME		"dc1"
> #define RTEMS_BSP_NETWORK_DRIVER_ATTACH
rtems_dec21140_driver_attach
> #endif
> result : DEC PCI not found !
> #if 1
> #define RTEMS_BSP_NETWORK_DRIVER_NAME		"wd1"
> #define RTEMS_BSP_NETWORK_DRIVER_ATTACH	rtems_wd_driver_attach
> #endif
> result : program hangs in "rtems_bsdnet_initialize_network ();"
routine.
> #define BSP_NE2000_NETWORK_DRIVER_NAME		"ne0"
> #define BSP_NE2000_NETWORK_DRIVER_ATTACH	rtems_ne_driver_attach
> result: program hangs in "rtems_bsdnet_initialize_network ();"
routine.
> PS : i have RealTek network card "RTL 8139 "
> can anyone tell me whatz happening ??
> Thanks In Advance
> Sachin.K
> Dexcel Electronics Designs (P) Ltd., Bangalore, India
