Problem with default gateway
    Ilya Alexeev
    ilya at continuum.ru
    Wed Jul 17 17:41:54 UTC 2002
Hello Mirko,
Wednesday, July 17, 2002 you wrote:
>> But nothing happens :(
>> rtrequest function can't understand that the 192.168.10.1 is
>> directly reachable from the eth0.
>> What I am doing wrong?
>> How to assign default route through such "almost" directly connected network?
>> Can anyone help me?
>> Best regards,
>> Ilya
MM> Is it possible that RTEMS does not forward "foreign" packets?
MM> I.e. did you set ipforwarding to 1 (netinet/ip_input.c)?
Yes, ipforwarding = 1.
MM> Also, as I understand, adding route means that the RTEMS board will
MM> SEND packets through some device. If you are not able to RECEIVE
MM> packets, maybe you should change net mask for your network interface,
MM> or even switch it to promiscuous mode (if applicable).
I am not able to add the default route.
IMHO, playing netmask and promiscuous mode doesn't help me :)
Ilya V. Alexeev
Continuum Plus JSC
Yaroslavl, Russia
Phone: (+7)0852 240200
Fax:   (+7)0852 359977
