Building RTEMS problem
Angelo Fraietta
angelo_f at bigpond.com
Tue Jun 4 22:17:20 UTC 2002
Try using these bit scripts that I am using. I am using Linux Red Hat 6
through a telnet session. To build the pc386 BSP I go
./bit_rtems i386 pc386
My rtems source is in a symnk link in the same directory called
RTEMS4.5.0ss
Davide Del Vento wrote:
>> > Of course my path is set correctly ;-((
>> Apparently not (cf. below).
> What's about the environment variables? Can the problem be in them?
> Now I'm nearly sure that I make an error in the ./configure options
> (see below)
>> > I do (in /opt/rtems/bin) "ln -s i386-rtems-gcc gcc"
>> Don't! This is plain wrong.
> I know, it was only a test.
>> > and I try to configure and make WITHOUT setting the path (I was
>> wondering
>> > where is the point where it hangs). This way it compile!!!
>> Well, .. no.
>> What might happen, is the native compiler not choking during compilation
>> of target code, because you probably are using an i386-based native tool
>> chain, but that's all.
> Right.
>> I'd guess, having started to configure without /opt/rtems/bin in $PATH
>> and then later having put /opt/rtems/bin in $PATH is the cause.
> No. (cfr below)
>> > > > Get your FREE download of MSN Explorer at
>> > >http://explorer.msn.com/intl.asp.
>> Are you using Cygwin? Then, there are other possible causes for your
>> problems.
> No, I use linux (Mandrake8.0 kernel2.4.3). This annoying spot is added
> by the webmail. I use hotmail (bleah!) because my university account
> is very poor and don't offer webmail at all.
>> Try to start from scratch:
>> Start a new shell, then
>> export PATH=/opt/rtems/bin:$PATH
>> mkdir build
>> cd build
>> <pathtortems>/configure --target=i386-rtems [further options]
> This was (nearly) exactly what I've done before: the only difference
> was that I type:
> <pathtortems>/configure i386-rtems [further options]
> My further options are simply: --prefix=/opt/davide
> So I retried with my previous configure options (and I obtained
> exactly the some error) and with your slight different ones (that
> should be equivalent, reading the ./configure --help)
> This way it hangs at a different point, as you can see from the
> attached output of the
> make all install
> Bye,
> ;Davide
> /usr/bin/install -c -m 644 o-optimize/libtest.a
> ../../../../../../i386ex/lib/libtest.a
> make[5]: Leaving directory
> `/home/marco/rtems/Davide/build/i386-rtems/c/i386ex/tests/support/wrapup'
> make[5]: Entering directory
> `/home/marco/rtems/Davide/build/i386-rtems/c/i386ex/tests/support'
> make[5]: Nothing to be done for `all-am'.
> make[4]: Leaving directory
> Making all in samples
> make[4]: Entering directory
> `/home/marco/rtems/Davide/build/i386-rtems/c/i386ex/tests/samples'
> Making all in hello
> `/home/marco/rtems/Davide/build/i386-rtems/c/i386ex/tests/samples/hello'
> mkdir o-optimize
> /opt/rtems/bin/i386-rtems-gcc --pipe -B../../../../../../i386ex/lib/
> -specs bsp_specs -qrtems -g -Wall -ansi -fasm
> -c -O4 -o o-optimize/init.o
> ../../../../../../../archive/c/src/tests/samples/hello/init.c
> -L ../../../../../../i386ex/lib -O4 -o o-optimize/hello.coff
> o-optimize/init.o ../../../../../../i386ex/lib/no-dpmem.rel
> ../../../../../../i386ex/lib/no-event.rel
> ../../../../../../i386ex/lib/no-msg.rel
> ../../../../../../i386ex/lib/no-mp.rel
> ../../../../../../i386ex/lib/no-part.rel
> ../../../../../../i386ex/lib/no-signal.rel
> ../../../../../../i386ex/lib/no-timer.rel
> ../../../../../../i386ex/lib/no-rtmon.rel
> /opt/rtems/i386-rtems/bin/ld:../../../../../../i386ex/lib/linkcmds:115:
> parse error
> collect2: ld returned 1 exit status
> make[5]: *** [o-optimize/hello.exe] Error 1
> make[4]: *** [all-recursive] Error 1
> make[3]: *** [all-recursive] Error 1
> make[3]: Leaving directory
> `/home/marco/rtems/Davide/build/i386-rtems/c/i386ex/tests'
> make[2]: *** [all-recursive] Error 1
> make[2]: Leaving directory
> `/home/marco/rtems/Davide/build/i386-rtems/c/i386ex'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/home/marco/rtems/Davide/build/i386-rtems/c'
> make: *** [all-recursive] Error 1
> _________________________________________________________________
> Join the world's largest e-mail service with MSN Hotmail.
> http://www.hotmail.com
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
Bernard of Clairvaux (1090 - 1153)
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20020605/8498c558/attachment.ksh>
URL: <http://lists.rtems.org/pipermail/users/attachments/20020605/8498c558/attachment-0001.ksh>
