problem in building rtems
Bhanu Nagendra P.
bpisupat at cs.indiana.edu
Tue Jun 18 15:28:27 UTC 2002
It is possible that the compiler is trying to write to directories where
you dont have permissions to do so. For example, if you are trying to
compile rtems as an ordinary user (not as root), then you do not have
write access to directories such as /usr/bin or /usr/local/bin
You can get over this problem by
a) running the compilation as root
or
b) setting the PREFIX variable in Makefile to some path inside your home
directory- this determines where the executables are compiled to and the
default value is /usr/local
/_) /_ _ _
/__) / ) (_)/ / \ \_/
On 18 Jun 2002, sudhir pola wrote:
> Hai,
> I an newbie. I am getting the following error when trying to build
> rtems.
> checking for executable suffix... configure: error: installation
> or configuration problem: compiler cannot create executables.
> configure: error: ../../../rtems-4.5.0-jg3/tools/build/configure
> failed for tools/build.
> I am using a sun-sparc machine with solaris 2.8.
> Can anyone help me out with this problem
> Thanks
> Sudhir
> _________________________________________________________
> Click below to visit monsterindia.com and there is always a
> better job for you at http://monsterindia.rediff.com/jobs
